Does anyone know what this grey gunk could be. It wasn't hard, more like the consistency of silicone caulking. It looked like it may have dripped down from the service entrance above but I'm not sure about that.
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It looks like duct seal, Telephone companies used to use it, we called Elephant .hit because of the package it came in .
Or it could wire lubricant
I would go with duct seal also, but seeing that it wasn't hard, I wonder if its some of the gutter sealant I've used in the past. It was grey and silicone like.
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Yes that what it is and thats what we always called it used piles of it ... Roy
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Roy you worked for the phone company?
In your picture, you can see that it fell directly from the vertically oriented conduit at the top of the panel. We used to install it at the horizontal conduit at the exterior elbow so that no water from the vertical outdoor conduit had even a chance to get into the panel. Holes were drilled at the bottom of the elbow to drain water entering at the masthead and other possible leaks. |
Electrician Both Brothers where also Electricians Stared helping them when I was twelve started the trade in 1951 .
Been in the IBEW for over 55 years my son also an electrician . Internation Brotherhood of Electrical Workers Cleaning up my garage found today some Glyptyol 40 years old . Found some Leathers for wiping lead cable pot heads over 40 years old . Dip pot for soldering Knob and tube wires Things we hang onto. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
OK, thanks guys.
Under the NEC raceways are required to be sealed when subject to different temperatures. Typically we use duct seal.
I have an old paper photograph somewhere of a panel in a basement with the meter socket and service mast on the north side of the house. It was February with a very cold (-15 or so *C) strong north wind blowing. The house had had a sewer backup into the basement a few days earlier so it was quite humid.......in the basement, the outside surface of the service conductors/disconnect breaker section at the top of the panel had about 1/2 inch thick frost/ice crystals on it!! No duct seal was being used when this set-up was installed.
I was A CWC Member Take care Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
| Grey Cup Game | dlevia | Canadian Inspectors | 9 | 11/28/10 5:02 PM |
| Grey drain pipe ok? | mnahrgang | Plumbing Inspections | 12 | 10/31/09 12:42 AM |
| is ALL grey piping poly? | bmargiotti | Plumbing Inspections | 3 | 2/24/07 11:10 AM |
| Grey Duct | rlavoie | Inspecting HVAC Systems | 5 | 11/13/06 2:48 PM |
| Grey stains on sidewalk spalling | kshepard | Exterior Inspections | 6 | 9/26/06 6:59 PM |
