Old 11/10/11, 7:37 AM
Anthony Picou Anthony Picou is offline
Please Note: Anthony Picou is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Grouding at the main panel
Hello everyone... my first post ! The first pic is the exterior panel just below the meter. Isn't the GEC supposed to be connected to the neutral in this panel ?
The second pic is the interior sub-panel. Comments on my above question and any other issues are welcomed ! Other than the GEC issue, I don't see any other problems with these panels (correct me if I am wrong).
http://imageshack.us/photo/my-images/155/img1346c.jpg/
http://imageshack.us/photo/my-images/254/img1355k.jpg/
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/10/11, 10:10 AM
Jeffrey R. Pope's Avatar
Default Re: Grouding at the main panel
The connection for the GEC should be visible in your first picture.
Additionally, there should be an equipment grounding conductor leaving the first panel and attached to the grounding terminal at the "sub" panel - it may be that the conduit is providing this bond, but it's not visible in your photos.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/10/11, 4:51 PM
Robert Meier's Avatar
Is this equipment listed for use as service equipment?
Old 11/10/11, 6:30 PM
Jim Port Jim Port is offline
Unmoderated Guest
I wonder if the bond screw is just below the neutral lug near the top of the buss?
Perhaps the grounding is in the meter socket?
Old 11/10/11, 6:31 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Not possible to tell from this picture. It could just be some home made fused disconnect from what is in the pic. Would need to see the entire enclosure and better yet the manufacturer label to answer your question.
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Sub panel main tripping? crichiii Electrical Inspections 6 12/28/06 10:08 AM
Main Panel location dmacy Electrical Inspections 5 12/6/06 6:32 PM
Main disconnect at meter instead of main panel. OK? kshepard Electrical Inspections 14 11/8/06 6:24 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
