Old 1/3/08, 6:17 PM
David C. Macy's Avatar
Default Ground connections at panel & exterior
Am I correct in stating that the exterior ground connection to the earth ground is improper and an acorn type fitting is required.
Also I see many times were the ground is installed thru the panel box improperly. Am I correct in saying vermin could enter the panel and this is improper as a bushing can not be installed properly.
Please correct me with proper verbage. Or would you let this stuff slide!
ID:	17173   ground-connections-panel-and-exterior-110708-037-small-.jpg.jpg
Old 1/3/08, 8:51 PM
Unmoderated Guest
Default Re: Ground connections at panel & exterior
You are correct on both counts.
I'll let the HIs advise how to word it.
Old 1/3/08, 8:54 PM
Mike Whitt's Avatar
Unmoderated Guest
Also if that is an eight foot rod it needs to be driven all the way down
Old 1/3/08, 9:26 PM
dbronsted's Avatar
dbronsted dbronsted is offline
The other thing that I see and I see it a lot is that the ground rod is inside the drip line of the house. That can be a dry area especially in dry weather. Grounds don't work as well in dry soil and should be installed outside the eve of the house. Our county electrical inspector (which I know that we are not code inspectors) requires all grounds to be installed that way. Any other ideas on this.
Old 1/4/08, 12:27 AM
Before I condemn the clamp I would need to see it a bit closer. Some are listed for burial. I agree there should be some better way to close that KO it is coming out of the enclosure through, or just use one of the 1/4" holes designed for the purpose. Mike is right about driving it all the way down. I used to carry a big hammer in my car for times when I found one sticking up like that. They didn't have an excuse for not driving it in then. It also saved them a "reinspection charge" which could be a couple hundred bucks if they were 3 counties away.
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Ground Wires Inside a Panel mveitenhans Electrical Inspections 13 10/29/06 11:39 AM
