Old 8/11/10, 3:02 AM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Ground Fault Circuit Interrupters (GFCIs) - New inspection article.
Find a Home Inspector
Need a home inspection in New Hampshire? Check out InterNACHI's listing of New Hampshire certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/11/10, 4:49 AM
Robert Meier's Avatar
Default Re: Ground Fault Circuit Interrupters (GFCIs) - New inspection article.
Nice job.
Old 8/11/10, 8:10 AM
Larry J. Michael Larry J. Michael is offline
Thanks for always providing great info Nick.
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Old 8/11/10, 8:56 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Thank you! I have been waiting for this one.
Post script, could you add something to indicate that an outlet can be protected if connected in series, or with a GFCI breaker. Thanks
Old 8/11/10, 8:03 PM
Sounds nice....BUT remember something. An OCPD ( Overcurrent Protection Device) protects againsts Short Circuit, Ground fault and Overload. There is a difference between a "ground fault" which a standard breaker protects againsts in its own inverse way.....just be clear that GFCI and Ground Fault are different things.
unlike standard circuit breakers, which guard against overloads and short circuits.
It really should read this way....
unlike standard circuit breakers, which guard against overloads, short circuits and ground faults.
Just in case you wanted to know........!!!!!!
Paul W. Abernathy
Old 8/12/10, 1:44 AM
Kate Tarasenko's Avatar
Kate Tarasenko Kate Tarasenko is offline
Thanks for the input, guys -- I'll pass it along to Ethan, and THANKS, Paul, for the factoid -- the article has been updated to include this fix.
Cheers,
Kate
Crimea River
Editor-in-Chief
kate@internachi.org
Old 8/18/10, 10:53 AM
Jim Port Jim Port is offline
Unmoderated Guest
Might be handy to add that a GFI will work without a grounding connection. However, if tested with a 3 light tester the GFI will not trip.
You could also add a section about supposed nuisance tripping from motors and refrigerators, freezers and sump pumps.
Old 8/23/10, 6:51 PM
lol....do you want an article or a novel....lol..just kidding Jim...
Paul W. Abernathy
Evaluating your home's wiring system mcyr Electrical Inspections 0 12/30/09 1:31 PM
Are electricians supposed to use these tools as per 70E? jtedesco1 Electrical Inspections 27 12/15/07 3:40 PM
Harmonized Ground Fault Circuit Interrupters jtedesco1 Electrical Inspections 5 3/21/06 8:48 AM
New Standards for GFCI's jbowman Electrical Inspections 8 2/20/06 9:48 AM
UL Information about Testing of GFCIs jtedesco1 Electrical Inspections 0 2/5/06 4:38 PM
