Old 10/2/09, 11:50 AM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Ground/Nuetral tie bar
There is a bar connecting the ground and nuetral busses. The busses should not be tied together at this particular (sub) panel. Does this bar come out or is there some other was to separate them?
Thanks in advance.
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 10/2/09, 12:03 PM
Jeffrey R. Pope's Avatar
Default Re: Ground/Nuetral tie bar
The bar is removable.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/2/09, 12:07 PM
rbrady's Avatar
Thank you Proffessor Pope!
I figured it was removeable.
Old 10/2/09, 1:16 PM
Unmoderated Guest
You just need to loosen the buss screw and then the screw thru the jumper and into the enclosure. The jumper is slotted to allow its removal from the bar.
Old 10/3/09, 10:05 AM
Paul W. Abernathy's Avatar
I still see a technical code violation in the first image.....anyone know...
Check out 408.41 ( Easy Fix )
Paul W. Abernathy,CMI,CPI,CME
Old 10/3/09, 10:38 AM
Ed Bancroft Ed Bancroft is offline
Paul,
Is neutral and ground allowed to have more than 1 wire per lug ?
Old 10/3/09, 11:17 AM
408.41 Grounded Conductor Terminations. Each
grounded conductor shall terminate within the panelboard
in an individual terminal that is not also used for another
conductor.
Larry Kage, CMI
231 929 3525
kluce kluce is offline
Please Note: kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by ebancroft View Post
Paul,
No and Yes. The neutral wires need to be separated while 2 wires under one connection is allowed.
Old 10/3/09, 11:31 AM
I did an inspection on a new construction yesterday and found the tie bar not removed in the Auxiliary panel. I took a look at some of the units that weren't done yet and seen the same thing. Ooops.
The plumber really screwed up by connecting the wrong water pipes to many of the fixtures. I seen hot water going into both toilets, Hot and cold reverse at many of the fixtures (kitchen and laundry tub was correct) and both showers producing nothing but hot water no matter where the handle was turned.
He has some work ahead of him since this is a slab house and most of the pipes are in the cement floor.
Old 10/3/09, 12:53 PM
Sean Fogarty's Avatar
You could always swap the lines at the water heater, and swich the lines at the sink. Problem solved!
Sean Fogarty
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
www.homeinspectionknoxville.com
Old 10/3/09, 7:20 PM
Paul,
Equipment Grounding Conductors YES- Based on listing of the terminal bar or equipment
Grounded " Neutral" Condutors - No and sometimes Yes....No in that under normal conditions like the one shown here NO. However, their is an exception which does not apply to this example but it does apply to some conditions.
conductor.
Exception: Grounded conductors of circuits with parallel
conductors shall be permitted to terminate in a single terminal
if the terminal is identified for connection of more
than one conductor.
