Old 11/3/08, 8:55 PM
Stewart Fip Stewart Fip is offline
Please Note: Stewart Fip is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Ground in panel
I'm adding some electric outlets to my home's basement. I was able to free up one of the breakers in my circuit panel and intended to tie this new circuit into it. Although I have easy access to the neutral bus bar, the ground bus bar is another story...I'm not able to reach it to attach the ground wire without a great deal of difficulty.
I'm wondering if I could cut one of the ground wires for an existing circut and wire-nut the three ends (two ends resulting from the cut, plus the new ground for my new circuit).
Thanks for your input.
Stewart
Old 11/4/08, 8:55 AM
Vince Santos's Avatar
Vince Santos Vince Santos is offline
Default Re: Ground in panel
If you are unable to access the ground bus-bar you should consider hiring an electrician for the installation unless you are comfortable/able to remove various conductors etc. to access this area.
Vince Santos
StepByStep Home Services LC
(734) 748-9584
Providing Home Inspection Services to Southeast Michigan
facebook
ITA Trained and Certified
Old 11/4/08, 10:26 AM
Jeffrey R. Pope's Avatar
Or just add another grounding terminal. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/4/08, 11:29 AM
You guys told me what I needed to know. Thanks! I sucked it up and dug my way down to the ground bus bar. It was easier than I thought! The new circuit works perfect.
Stewart
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Ground Wires Inside a Panel mveitenhans Electrical Inspections 13 10/29/06 11:39 AM
