sstevens1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
An electrician informed me that on a house that I inspected I did not document to the client that the outlets were installed incorrectly throughout the house. I was told that the NEC requires 3-prong outlets be installed with the ground slot at the top of the outlet. I informed him that I have not heard of that and that the outlets were wired properly. Has anyone of ever heard of this or reported this? Thanks.
I am aware of no such requirement, however, some "old school" sparkies I know, say that this is the way they should be.
It's a matter of preference. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I agree with Jeff that there is no model code requirement for the ground slot to be on the top, and this topic has been the subject of many debates (check the BB topics on this at www.mikeholt.com)
However, I agree it's better practice to have the ground slot on top so that if anything metal (receptacle cover plate, paper clip, knife, etc) happens to fall on a receptacle with a loose cord, then it will hit the ground prong. I would politely ask the sparky for an NEC code reference for ground prong to be on top, at which point the whole issue will probably go away ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
What about this one...
Attachment 880 Last edited by dvalley; 10/7/07 at 5:41 PM.. |
JMO and 2-nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Seen a lot of outlets with the ground up for years, of course it was almost always indicative that it was a 'switched' outlet... I've pointed it out to clients for years...
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
I'm not aware of any NEC requirements for receptacle orientation. I am aware that many medical facilities and hospitals require the ground slot up especially near beds where the pull chains, etc. might fall across a plug not fully engaged in the receptacle. Frequently I find ground-slot-up receptacles in homes I inspect alerting me that it may have been installed by the homeowner. Otherwise, the only problem I have is that the ground-slot-up receptacles are upside down and my receptacle tester faces the floor.
Joe |
lfranklin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Why do most cords have the grounds at the bottom?
If the ground pin is up, what is that 50% chance that something will not fall against the hot? This could be a long thread and go for a long time. Heard both sides from why it should go up and why it should go down. Why do most electricians put the wide blade on top when installing sideways? Is this in the NEC |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 12:39 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
| Harmonized Ground Fault Circuit Interrupters | jtedesco1 | Electrical Inspections | 5 | 3/21/06 9:48 AM |
