It is correct to say that in the main electric panel that the ground and the common wires are not suppose to be attached to the same terminal strip which each other. Should the ground be on one terminal strip and the common wire on the other.
Billings Inspections services William (Bill) Billings Billings Home Inspections LLC Billings Inspection Services LLC Billings Contracting LLC CGC 1516427 www.billingshomeinspections.com |
They can be on the same terminal bar, but under separate screws. . .
Thanks Jeffery, I was not positive about this.
Bill Billings Billings Inspections Services William (Bill) Billings Billings Home Inspections LLC Billings Inspection Services LLC Billings Contracting LLC CGC 1516427 www.billingshomeinspections.com |
Newer panels have specific listings for their terminal bars, so there are some where the different conductors should be attached to separate bars, but the fact is, both are bonded to the enclosure at the service equipment.
There is NO such thing as a "common" in the panel.
There is the neutral (or more technically: grounded conductor) and there are grounding conductors. |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Petey
Some people will call the grounded (neutral) common. I see about 75% of my students call the grounded (neutral) common when they first come into class. This is a "common" (pun intended) mistake through out. |
Must be regional.
I never hear the term in Chicago |
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
I was just pointing out that it is not correct, and never was. |
New in the NEC on page 99: ...... "common grounded conductor(s) terminal or bus."
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 11:39 AM |
| Harmonized Ground Fault Circuit Interrupters | jtedesco1 | Electrical Inspections | 5 | 3/21/06 8:48 AM |
