Old 8/22/11, 8:12 PM
Jeff Merritt Jeff Merritt is offline
Default Ground wire split at buss bar
I see this from time to time, I call it out as not best practice, how do you write it up?
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/22/11, 8:17 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Ground wire split at buss bar
I don't know why that was done. Looks like #6 and a #4 will fit in those holes. Improper termination technique.
Old 8/22/11, 8:33 PM
It was # 6 and would not fit the hole.
Old 8/22/11, 9:19 PM
Christopher Currins's Avatar
Not best practice, but what harm can it do?....Arcing?
Christopher Currins
Certified, Licensed
Old 8/22/11, 9:32 PM
Robert Meier's Avatar
Probably no harm at all. Still isn't right. I'm with Jim on this one, I've never seen a bar like that where a #6 AWG conductor wouldn't fit.
Old 8/23/11, 12:32 AM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
Came across this neutral service entrance conductor termination not too long ago, my narrative was;
•The large gauge stranded neutral wire on the service entrance conductors was split into 3 and each terminated under a separate screw on the neutral bus bar. This is not in accordance with standard industry practice. Recommend that this connection be further evaluated by a qualified electrician.
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 8/23/11, 7:31 AM
Unmoderated Guest
Under the NEC that is wrong. The neutral must terminate in a single connection. No need for further evaluation. It just needs correction.
Old 8/23/11, 9:38 AM
Jeffrey R. Pope's Avatar
Yep.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Ground wire in neutral bar, neutral to breaker, hot to ground? rmc3inspection Electrical Inspections 4 8/1/06 9:44 AM
