Does anyone have good verbage but yet simple to understand for this issue. They did nice work, nice and clean. Again, the AHJ must accept this? Thanks
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
| Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America) |
Gary,
This was covered as part of the UL standard, but was not a direct part of of the NEC until recently. The current code calls for 1 neutral per terminal, not to be shared. Grounding conductors may share with other grounding conductors if the buss is labeled for them. Most are. The currect Article is 408.41. |
Finally I would not assume that the AHJ has approved the panel or that they are as knowledgeable as they should be. Frank P. Newman Emerald City Inspections, LLC Dublin, GA |
Just because something was PASSED does not mean it is allowed. Not all inspectors are created equal......they just might not know any better.
Paul W. Abernathy |
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 2:00 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
| Almost understanding grounding and bonding | Ian Gills | Electrical Inspections | 22 | 12/8/07 2:18 AM |
