Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 10/13/09, 8:38 AM
Ralph M. Smith Ralph M. Smith is offline
Default Grounding
Hi Folks, The wiring appears to be grounded to the panel box, including the 40 and 50 amp breakers. The main entrance cable also is grounded to the box. I was unable to determine the grounding of the box to ground as this panel is in a finished basement wall. No rod was seen at the exterior and the water meter is in a closet type door at the far end of the finished basement and could not see a ground wire there also. Is this a safe installation if it is properly connected to ground?
Ralph M. Smith; CMI, CHI, CI, CEO
S.H.I.R.E. Inspection Services, Inc.
"Your Home is Our Business"
http://shireinspect.com
Find an InterNACHI certified Kansas Home Inspector (and anywhere else in North America)
Old 10/13/09, 10:39 AM
Jeffrey R. Pope's Avatar
Default Re: Grounding
I'm not sure how well those connections will function, but this is aged equipment and may be sufficient. However, there must be a system ground such as a water pipe or ground rod. If you did not observe a GES, you should recommend that it be verified by a qualified electrician.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/13/09, 2:18 PM
Thanks Jeffrey!
What do you think? Can this work for you? jtedesco1 Electrical 13 2/9/09 11:58 PM
"UFER" Ground? see last paragraph. jtedesco1 Electrical 6 9/15/08 8:57 AM
What's this video worth? jtedesco1 Education 5 4/18/08 10:24 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
