Old 3/29/11, 7:14 PM
pkelley's Avatar
pkelley pkelley is offline
Default grounding & bonding
When you have two electrical panels side by side , In other words 200 amp service in to a home with the second panel acting as a sub panel , does the second panel require its own separate ground. or is bonding to the main panel which is grounded , sufficient
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/29/11, 7:27 PM
Robert Meier's Avatar
Default Re: grounding & bonding
An equipment grounding conductor run with the feeder and sized according to the OCPD ahead of the feeder is all that's required.
Old 3/29/11, 9:47 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
It does not need a separate ground. If the panels are bonded together by a conducting conduit, make sure the sub-panel neutral bar is not bonded to the panel and the equipment grounds are separated from the neutral buss on their own buss attached to the sub panel.
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Old 3/30/11, 4:54 AM
Good point. You still need an EGC (equipment grounding conductor) between the two panels but, as Gregory stated, that EGC is not required to be a separate wire conductor. It could be a metallic raceway or a metallic fitting that is an approved equipment grounding conductor.
Old 3/30/11, 7:39 PM
Key here is....a conductor is not always a "WIRE".....always keep that in mind. For approved EGC's see [250.118]
Paul W. Abernathy
Old 3/30/11, 8:02 PM
Roy D. Cooke, Sr's Avatar
And then there are other types of conducters .
My dad worked for the rail way and I wanted to be a conducter .
Old 3/30/11, 8:10 PM
Awesome......My grand father was a conductor as well. He died 30 days before I was born and never got to meet him.....He's waiting to meet me now...I told him last night (prayers) that I will meet him someday (just not soon I hope)
Paul W. Abernathy
Old 3/30/11, 9:12 PM
My Grandpa and my Dad were Engineers on the South Shore railroad. No picture to share but I will get one. I blew the whistle at 10 but ended up being the other type of engineer. (They have much better retirement!!)
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Demystify Grounding & Bonding Class pabernathy Inspection Education & Training 5 12/24/06 1:10 AM
