Bill Hall is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi
I was wondering if someone could help me? I live in condo unit. I know a little about electrical things. I was looking in my panel and I could not locate my ground wire. I do have a main shut off my service is 100 amps I have 8 circiuts. Is my panel being used as a subpanel and grounded by the conduit? Thanks Bill |
Post an image of your panel, and we can help you locate your ground cable... |
I do not have a digital camera.
Ok...Lets start by following your cables that enter the panel. There should be three.
You stated that you see a main breaker. Two of the cables (that enter the panel) are tapped into the main breaker. Where does the third cable go? |
Neutral bar
There's your ground....
thanks i just always thought you should have a ground going from the neutral bar to a water pipe or a grounding rod
That would be by the meter right
The ground cable you are referring to should be on the inside wall behind your meter. If you are in a condo unit, there should be a room there with meters for every dwelling in the building. |
ok thanks for all your help very much appreciated
That's where you'll find your grounding cable.
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 2:00 PM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
