Hey Guys,
Take this little QUIZ and reply and I will tell you who got the MOST right. Just number your answers TRUE or FALSE in numeric order. Myths of Grounding
Paul W. Abernathy |
1.True
2.False 3.False 4.False 5.True 6.True 7.True 8.True 9.True 10.False How bad did I do? |
11. Coffee grounds are postively charged.
True or False |
lol.....I think Brian is ON TO ME with this little QUIZ...lol
Paul W. Abernathy |
Paul W. Abernathy |
I like the quiz Paul, but I have to look up most of the answers.
I am not an electrical expert.
I'll admit that I am not sure about my answers. The questions are kind of like the ones on the drivers license test, kinda tricky. |
Paul W. Abernathy |
The last 4 are true
... if you add the word impedance to #8. |
Greg...please provide me with your take on WHY the last 4 are true statments. I am quite interested in it if you don't mind.
Paul W. Abernathy |
The things you reference in the last 4 are all referring to common mode transients. They are all going to find another path to ground if you don't give them one. #8 is poorly worded so it is hard to figure out what they are really asking but if you are saying the lower the "... impedance to ground..." I say it is true. The difference in potential between the EGC and the dirt will be lower. (zero?)
lol....these are not mine greg as I got them from Mike Holts site, he says they are all FALSE on his site and I wanted to get others opinions on them.
Paul W. Abernathy |
I guess I'm only batting 400.
I heard 300 was a good batting average. |
ahh...you are good Wesley....it was just a fun thing and to be honest with you..this is why I idol Mike Holt......I did not get them all right myself when I did it...he explains things very well.....
Oh to be Mike Holt.... Paul W. Abernathy |
Perhaps Mike Holt has never really studied lightning.
IBM did a lot of studies on this in the lightning capital of the world and concluded it is very important to have a good grounding electrode and that it be used by all utilities. We went from blowing up 50 boxes a week to virtually zero. Our stuff works. The easy example is your modem. An ungrounded TVSS might do a great job of shunting the voltage on the supply side and preventing the circuitry from seeing a line/neutral surge but if the whole modem rises several hundred volts from ground that difference will be made up on the telephone side that has it's own grounding coinnection and it goes boom. As for #8, if your EGC is bonded to the neutral and not well grounded the difference in potential between the case of your stove and the terazzo floor in your kitchen (on a slab) can be shocking. (a defect in this house when I moved in) My "zero" standing on the floor was not the same as the utility "zero". In the computer biz I have measured 35 volts between the ground of buildings 20 feet apart. "Local" ground is very important. It is why 250 says we drive a rod (or 2) at every building. In the computer biz we also bonded all of these together with a fat wire. If a data cable went somewhere we also ran a big bond. All I can say about # 9 is to read Article 547 and the USDA articles about bonding grids and the ground rods you should have in a dairy barn. That is all to prevent stray current. The stray current is between "ground" where the power comes from and the dirt where you are using it. They say, if you have a stock tank warmer, you should bury a ground ring around it and bond the tank. At the door of a barn you should be burying rods out in the dirt on the apron bonded to the steel in the floor. Perhaps I misunderstood 10 since my thoughts were the same as the statement starting with "however..." I think he interntionally made the wording vague on a few so he could make the case for "false". It was my first impression that he was going for all false but about #7 I saw he may be going astray. |
| Shane Boyd, here are IAC2's requirements: | gromicko | IAC2 Indoor Air Forum | 1 | 11/12/06 8:05 PM |
| Can you guess what goofy inspection trade association requires all this?! | gromicko | Canadian Inspectors | 7 | 8/26/06 3:11 PM |
