Courtesy of Mike Holt Enterprises...
Mike, after reading the document you sent me, my mind exploded with assumptions, and specifically the grounding/neutral systems of Puerto Rico. I hope you offer these thoughts to your newsletter readers and experts so they can provide us all with their thoughts. I call this THE GROUNDING "TRUTH." The Earthing Systems' Worldwide document is most illuminating and, as you say, you don't think there is a technical reason to ground the distribution system within a building and that there are more ways of using the earth connection. In fact, there are places in the world, like Norway, where distribution systems don't have any grounding; some don't even have a neutral at the high voltage. You should carefully read this document yourself as it helps to better understand the issue of grounding and why the U.S., and Puerto Rico for that matter, is one of a couple of countries that grounds every neutral and metal part they can. Mike Holt's Comment: And probably Iraq and Afghanistan in the next few years when we get done with them. The principle of grounding comes with the mysterious capacitance that is created between electrical wires and the earth itself. This develops a potential just waiting to complete a circuit. The completion comes when ground fault occurs. At that moment, the fault current is very small due to the nature of the circuit (line-air-earth-line, imagine the impedance). It seems that generally this current is harmless, but if for some reason it increases or becomes a true short by means of another path, it certainly may become dangerous. Obviously, at the time the distribution system began, no sensitive devices were available to protect against this kind of fault, so earthing the system provided a more manageable current (ironically higher) and protective devices could be manufactured. This is all besides the obvious protection against lightning. That action alone created the "common knowledge" that grounding was necessary for the electrical systems. The method used by Norway is known as the IT System and the only things grounded are the metal casings and parts at the load, which share a common ground line NOT bonded to the neutral. Norway uses it particularly because the earth has very low conductivity and other countries use it around hospitals or where human safety is emphasized. There are basically two other systems; the one used by the U.S. is the TN System in which all neutrals, casings, and metal parts are bonded to the earth. Essentially, this system forces the earth to share the common point of the distribution system. The pros of the TN System are that it's very easy for protection devices to detect faults and the earth can be used as a (supposedly) temporary conductor to maintain the continuity of distribution. The cons you know better than me - the earth is now "energized" directly at the distribution's potential and its wide use as a conductor is becoming a hazard for people and animals. As no devices are created for separating the service neutral from the load neutral at a high-voltage fault, all the loads are affected by it. Also, the quality of the signal is diminishing as more demanding and sensitive equipment is used in the continent and my island. A measure of improvement is the use of the fourth wire at the loads, where this wire goes directly to the neutral of the service and provides a better, less dangerous path for the fault currents. The last system is the TT System where the supplies' neutrals are grounded and only the casings and metal parts of the load are grounded. This provides for better detection of low-power ground faults and, although the earth is still used as a conductor for these faults, their paths are less and accidents are fewer. This is the most widely used grounding system in the world, a product of its versatility and reasonable cost of protection devices. In conclusion:
Julio Trujillo Electrical Engineer Puerto Rico Paul W. Abernathy |
Ahh....reminders of a day gone by
Paul W. Abernathy |
| Interesting article about mold by litigation. | gromicko | IAC2 Indoor Air Forum | 16 | 5/5/11 7:48 PM |
| Final review of Newman's radon references! | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 12 | 10/4/08 12:23 PM |
| Grounding -V- Bonding Article (Good Read) | pdoane | Electrical Inspections | 0 | 10/12/06 4:31 PM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 10:06 AM |
