Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 4/13/08, 5:53 PM
Maxim Kiss Maxim Kiss is offline
Default Grounding wire close to water heater
Hi Everyone,
I got a question. In a 20flat I inspected yesterday, I saw a grounding wire being bonded to a cold water pipe supplying a water heater. The wire was attached about 3.5 feet away. First of all, is it OK? Second, should hot, cold and gas piping at the water heater be bonded together. Is jumper necessary? It's just I've never seen this kind of grounding to a water pipe.
Old 4/13/08, 5:57 PM
Marc D. Shunk's Avatar
Default Re: Grounding wire close to water heater
What you likely saw was "bonding", and it's both required and a good idea. In the event that something should energize the pipework in each unit, there will be a good ground fault path back to the panel to allow the breaker to trip (mitigating the hazard). As long as one pipe (either hot or cold) is bonded, the other one is likely bonded as well via the water heater and various mixing valves like on the kitchen sink, bath lav, and shower valve. Gas pipe bonding is usually accomplished by factory connections that already exist in gas appliance that utilize both gas and electricity such as warm air furnaces. No extra bonding is normally required for gas piping, but doesn't hurt a thing if a guy adds some.
Old 4/13/08, 10:26 PM
Thomas H. Dietrich's Avatar
Thomas H. Dietrich Thomas H. Dietrich is offline
Technically, anything that could energize any metal piping, should be properly grounded by the eqc that feeds that circuit. However, some inspectors want to see the water piping on the water heater bonded as well. Just one weird thing, you said the cold water side was bonded? That doesn't make sense, at a minimum it should be the hot water side, since that would be the broken side if the water heater is removed.
tom
Old 4/13/08, 10:28 PM
tom
Why, you inspect units that don't have kitchen, bath, and shower faucets?
Old 4/13/08, 10:33 PM
Not home inspectors! Like myself.
Talking about municipal electrical inspectors. I still do electrical work, for free. We AHJ that want over kill.
tom
Old 4/13/08, 11:42 PM
The problem with that idea is the plastic supply line from the faucet to the angle stop.
Old 4/13/08, 11:49 PM
Never saw a shower done that way.
Old 4/13/08, 11:57 PM
To be honest I haven't seen any metal pipe in new construction since the Carter administration. It is all PVC and CPVC around here.
Hot water first then cold out of cold side of fixture jberthiaume Plumbing 19 3/12/08 2:32 AM
Nat Gas water heater electr. bonding lfreeze Electrical 14 1/15/07 11:16 PM
Need Help On Chimney Liners Nick Scibetta Exterior 10 1/11/06 10:53 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
