Just need some clarification. Are handle ties required on these circuit breakers? For example, on the bottom left, first 3 breakers. Are these considered 2 ckt's to receps on same yoke? Just need some insight is all.
Hi Charles,
No handle ties are not required, those breakers are commonly called "mini twins" and each handle is controling a seperate circuit. You would only need ties if they were controlling one appliance as you sometimes see with 2 seperate breakers running each leg of a 240 volt circuit (AC, stoves etc) I hope this helps Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thanks Gary,
This is what I thought...just needed some clarification...thank again Chuck |
You may want to mention the recalled AFCI breakers in that panel. . .
Yep, I remember that post on the recalls...Thanks for the heads up Jeff
Chuck |
http://www.cpsc.gov/cpscpub/prerel/prhtml05/05035.htmlour
Nice catch Jeff. I can tell that you are not an alarmast from your comment on the AFCI. |
With all the different things we have to bear in mind, how do you remember an item on a recall list from 2 years ago? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Recently, one builder finally took the high road and replaced the AFCI breakers in over 750 homes, in a tract where I called it out on more than 20 homes. The replacement breakers have a green test button. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
How have the replacements been going. Is SqD living up to the promise to cover the labor?
I was under the impression not all "Blue Button" SQ-D AFCI's are in the recall, I would have to search for the list I saved that Paul posted though.
Are they? |
Whew..Back from Atlanta......figured I would chime in...
Be aware that on those tandoms in the panel shown...that none of them go to a multiwire circuit and share a neutral ( grounded ) conductor.....as in doing so would put BOTH loads on the same LINE in the panel and compounding the load on the grounded conductor of that circuit. The only reason I bring this up is your statement on (2) circuits on the same YOKE............would generally constitute someone trying to do a Multiwire circuit in most cases....and tandoms should NOT be used for this application. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Paul,
Good info - I just saw one of the exact situations you mention . ![]() This unlabeled tandem circuit breaker feeds a three wire w/ground romex cable. Either it is an improper multi-wire circuit or improper 240 v circuit. Don't know which - don't care - it needs attention by a licensed electrician. tg |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
What is all the dirt/dust on the circuit breakers at the left side of the panel all about?
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| Can an AFCI offer GFCI protection | gbeaumont | Electrical Inspections | 19 | 7/7/06 12:45 AM |
