Old 9/7/08, 5:53 PM
sfalvey sfalvey is offline
Default Hard wired dryer
Any problem with a hard wired dryer. The ground is obvious.
Thanks,
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 9/7/08, 5:56 PM
Marc D. Shunk's Avatar
Banned
Default Re: Hard wired dryer
Well, that's only #12, and you need #10 for any domestic clothes dryer that I've ever seen. It can be legal to hard wire a clothes dryer, but it needs a disconnecting means within sight of the appliance.
You've pointed out the goofy way the ground is terminated, but that 3/4" romex connector is probably not rated for the 12-3 that's running through it.
Old 9/7/08, 6:00 PM
Thanks Mark, that is a good find. This house is full of things like this. Check out other posts at the plumbing section.
Thanks,
Scott Falvey
Newbury, NH
NACHI#05051292
Old 9/14/08, 6:14 PM
If one chooses to hard wire the dryer, I believe it should be in conduit.
Old 9/15/08, 12:01 AM
The violation is the lack of a disconnect, and in your case the undersized wire and the use of Romex (that gets debated from time to time).
Dryer sheets potential hazard badair Miscellaneous Discussion for Inspectors 15 7/9/11 2:39 PM
Flex vs. hard gas hookup to dryer Nathan W. Swilling Plumbing Inspections 18 4/2/08 10:54 AM
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 9 9/9/07 7:02 PM
direct wired dryer msaxton Electrical Inspections 5 4/3/06 11:34 PM
