Old 3/2/09, 9:35 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Default Has anyone ever seen conductors like this?
First time for me! These conductors were directly below the carpet.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 3/2/09, 10:34 PM
tdietrich1's Avatar
Default Re: Has anyone ever seen conductors like this?
Yes, I've seen that 'type' before. Typically it is very flat and attachable to walls, so you can power big screen TV's hanging off of walls. To hide the flat cable, it is paint-able.
Being wall mounted cable, I believe it's considered not exposed to physical damage.
hope this helps,
tom
Old 3/3/09, 10:38 AM
Jim Port Jim Port is offline
Unmoderated Guest
There was a system similar to what you pictured, however it was only to be used under carpet tiles.
Old 3/3/09, 5:25 PM
Jim,
You are correct sir!
These conductors were used under carpet tiles. I have never seen this before last night’s inspection. It was an IR inspection to locate areas with moisture/water intrusion. The contractor removed the carpet tiles and this was found below. He immediately killed the power to these circuits. .
Tel.# 416-722-6132
Old 3/3/09, 9:09 PM
tdietrich1's Avatar
So those must be these: http://www.ampnetconnect.com/documen...408-3154_E.pdf
Not these: http://gizmodo.com/gadgets/wired-wor...int-256691.php http://www.decorp.com/decord.htm
tom
Old 3/4/09, 9:00 AM
Yes they are Thomas, Thanks for the PDF file!!
Tel.# 416-722-6132
Old 3/4/09, 6:37 PM
Unmoderated Guest
For reference that is in the NEC as:
ARTICLE 324 Flat Conductor Cable: Type FCC
I did a bunch of that stuff in a Radio Shack I wired years back.
Old 3/5/09, 9:28 AM
Bryce W. Jeffrey Bryce W. Jeffrey is offline
I checked with the operations manager of the St. Thomas Energy Services and he says they are not approved in Ontario.
Old 3/6/09, 6:45 AM
Gerry Pallotta's Avatar
Gerry Pallotta Gerry Pallotta is offline
Send a message via Yahoo to gpallotta
Mario
Check out here.
Old 3/7/09, 10:08 AM
They better be approved, this installation was found at a Government Building. I have a re-inspection on Mon. I will talk with the electrical contractor to determine if these conductors are currently approved for use, and if they are no longer an approved product, when they were disallowed.
Tel.# 416-722-6132
What do you think? Can this work for you? jtedesco1 Electrical Inspections 21 2/26/11 2:00 PM
Where is it written.... bgromicko General Inspection Discussion 21 1/19/08 9:02 PM
Article 240 : Overcurrent Protection Article pabernathy Electrical Inspections 0 5/23/07 11:40 AM
Need Help from the Learned... gbrasseur Electrical Inspections 15 12/19/06 5:04 PM
