I was having trouble getting the camera to focus properly but not enough to create this kind of temp on a neutral wire. Be curious to know what the sparky is going to find on this one. Of all the panels I scan this was my first to come up with a high temp on a neutral wire. I just kinda stood there with this dead brain took a minute to register
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Since it appears that these are all two wire circuits my guess would be that it's a loose neutral connection, otherwise you should find a similar temperature at the hot conductor connected to the CB.
This can happen on some panels if the breaker is installed incorrectly. If that is the case easy fix move the two pole breaker down one position ..... Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I'm assuming that you're referencing a MWBC which shares a neutral. Wouldn't there be a red conductor in the panel if there were a three wire cable with a shared neutral? |
This forum is great gets us all looking and learning Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
AGREED! I do not touch but I look really close at the connections. If I don't see good contact I call it out every time.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
