Old 3/10/08, 3:41 PM
Ben J. Gromicko's Avatar
Ben J. Gromicko Ben J. Gromicko is offline
Default What is he holding?
Every home inspector should carry one.
BEN GROMICKO
InterNACHI Director of Education
Now That You've Had a Home Inspection" Book
Old 3/10/08, 4:20 PM
Michael Larson's Avatar
Default Re: What is he holding?
Attachment 19402
I've got one, seldom use it.
Ben, Do you check every outlet for blade and ground pin retention?
Michael Larson
Hudson, WI
Old 3/10/08, 4:25 PM
No. Never even heard of such a thing until Joe showed me.
BEN GROMICKO
Old 3/10/08, 4:34 PM
Roy D. Cooke, Sr's Avatar
Never test this and never even test all Plugs in the Home.
My guarantee is I will miss some thing in the home.
Cookie
Old 3/10/08, 4:45 PM
Jeffrey R. Pope's Avatar
I use this only on new construction and one-year warranty inspections.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/10/08, 6:00 PM
But the idea of the tester is to see of the tension is still good. Typically a concern about old plugs - not new ones. ?
BEN GROMICKO
Old 3/10/08, 6:05 PM
Not worth $80 IMHO.
If someone wants one, you can buy it HERE or Here
I have one from a previous career.
Michael Larson
Hudson, WI
Old 3/10/08, 6:36 PM
This is in NFPA 73:
"4.9.8 Receptacles that fail a blade retention test, with a listed retention tester, shall be replaced."
Old 3/10/08, 6:48 PM
Originally Posted by jtedesco1
This is in NFPA 73:
So?
Joe we are not code inspectors. ( I know you know this, I saw you say it in your video)
We have no authority to order anything done.
NFPA 73 may be a useful document but you won't see it incorporated into any association's SOP any time soon.
Michael Larson
Hudson, WI
Old 3/10/08, 7:01 PM
In all my years of operating a home inspection business, I never felt powerless to make a change. As an inspector, I felt an enourmous amount of focus on my words and opinions. I found my recommendations being implemented within days if not hours of writing my inspection report.
It just didn't matter that I was not the AHJ. My recommendations were followed through. There was typically too much riding upon it.
BEN GROMICKO
Old 3/10/08, 7:08 PM
In all my years of operating a home inspection business, I never felt powerless to make a change. As an inspector, I felt an enourmous amout of focus on my words and opinions. I found my recommendations being implemented within days if not hours of writing my inspection report.
Yes I hope and expect all my recommendations will be implemented but I have no "authority" to make sure it happens.
Michael Larson
Hudson, WI
Old 3/10/08, 8:49 PM
Marc D. Shunk's Avatar
Banned
Receptacle tension is tested by "rental inspectors" in cities with regular rental property maintenance inspections. Loose wires cause fires, as the saying goes. Lack of appropriate receptacle tension is the same thing; a potential genuine hazard. By the time you seen brown heat stains on the face of the receptacle, the thing has already been trashed for quite some time. The use of a Woodhead type receptacle tension tester can head off potential property loss.
Old 3/10/08, 9:01 PM
Unmoderated Guest
Just a side note.
This is what I meant in the past when I have said that your reports and requests are given much more weight than many of your guys like to think.
I often get the same impression as Ben when dealing with a H-I's report.
It is common to hear: "The inspector said this NEEDS to be done.", or "We HAVE to do this to sell the house. It's in the inspector's report."
Old 3/10/08, 9:44 PM
Gosh Marc, that was spoken like a true slumlord, no mention at all of loss of life.
Old 3/10/08, 9:55 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's why I don't use a listed retention tester.
I was thinking up rigging up a 2-prong plug with a small weight and use that if I suspect worn receptacles.
Sewage Holding Tanks gluck Canadian Inspectors 10 7/23/07 9:03 AM
NACHI member Kenny Hart holding 1-day training, Alpha College, Virginia Beach, Aug 26 gromicko Miscellaneous Discussion for Inspectors 1 8/21/06 10:03 PM
NACHI member Kenny Hart holding 1-day training, Alpha College, Virginia Beach, Aug 26 gromicko Inspection Education & Training 0 8/14/06 2:19 AM
Chicago NACHI Chapter holding officer elections in Hillside, IL on May 18, 2006. gromicko Miscellaneous Discussion for Inspectors 1 5/8/06 8:40 PM
NACHI North Texas Chapter is holding a logo contest. gromicko Miscellaneous Discussion for Inspectors 1 4/24/06 2:40 AM
