Old 3/13/10, 11:15 AM
pnarron pnarron is offline
Default Heat Pump
If the outside unit calls for a 30amp breaker and the panel has a double pole 60 amp breaker ; this should be called out right. The outside unit has a cooling fan that is seized up also. The reason that I'm asking is that a code certified inspector had inspected the home 2 weeks prior and there was nothing about the breaker in his report. ( client had a copy)
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/13/10, 11:36 AM
Jeffrey R. Pope's Avatar
Default Re: Heat Pump
Was there an OCPD in the disconnect? If not, then the 60 amp breaker is too large - assuming you are referring to the maximum breaker size.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/13/10, 11:44 AM
Yes there was, that explains why the other inspector did not call it out. Thanks for your help.
Old 3/13/10, 11:58 AM
Robert Meier's Avatar
What size conductors are connected to the 60 amp breaker?
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 16 1/24/12 10:46 AM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 10:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 12:15 AM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 22 2/1/06 12:56 PM
