Old 2/5/10, 1:22 PM
mivie's Avatar
mivie mivie is offline
Please Note: mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Heat pump breakers
A 3100 sq foot home. 200 amp box with 2 100 amp breakers for the heat pump. Is this normal?
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/5/10, 1:26 PM
James E. Braun, CMI's Avatar
Default Re: Heat pump breakers
No, I would get your amp ratings off the unit or get the model number and pull up the specs. The biggest breakers I have seen on a residential HVAC unit was 60 amps and that is for electric heating elements
Old 2/5/10, 1:33 PM
mivie's Avatar
I told him the same thing. This is not from an inspection it is a friend that lives in another town. He called and said the breaker was hot. Wanted to know if it needed replaced.
Old 2/5/10, 1:37 PM
If the breaker is hot than there is something drawing way too much current such as an electrical short.
Old 2/5/10, 1:39 PM
mivie's Avatar
He told me he has been running the heat strips for over a week.
Old 2/5/10, 1:48 PM
I have never seen heat strips on a residential furnace pull that much current. A lose connection somewhere could cause excessive amp draw, or a maybe even a field grounding out in a motor. Just pull the amp load on each wire until you find it.
Old 2/5/10, 1:49 PM
mivie's Avatar
Thanks James. I will pass this information along.
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 16 1/24/12 10:46 AM
Heat pump in a 80+ year old masonry house jskrypka Inspecting HVAC Systems 9 11/25/06 10:47 PM
Question on my heat pump dbush Inspecting HVAC Systems 7 3/12/06 12:15 AM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 22 2/1/06 12:56 PM
