Anyone remember, off the top of your head, the height requirements for the safeties (photocells) on a garage door? I am out of the office and could use the info.
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
6 inches..........i think
Yep. 6 inches.
I would never bother to get the tape out to check though......eyeball 6
This one is 31 inches, by the tape..... Had trouble eyeballing it!!! LOL Thanks guys!!! |
Chuck Lambert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Manufacturers 4-6 inches so it will stop and reverse the door if a small child were to crawl through the beam.
Chuck |
I could eyeball that one without my glasses.........couldn't read the tape though!
Yep.. 6 inches. Just remember a "small childs head" should break the beam.
Pull the instructions down off the garage door opener (where I usually find them) and show the appropriate section to your customer!
- Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
Here is a handy hint if you should forget your measuring stick - US Paper currency is presently standardized at 6-1/16 inches. Pretty darn close for our purposes to 6 inches.
Fold it in half - 3 inches: Fold it in thirds - 2 inches: Fold it in thirds & open one fold - 4 inches (for checking railing spindle(picket) spacing. Also good for an uncertain eyeball to confirm 2X6 or 2X8 - just remember though- a 2Xwhatever isn't, depending on the era it was sawn. |
tneyedli1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Min. of 2 inches to a max. of 6 inches are req'd. T.Neyedli CHI www.alphahomeinspections.ca |
Parents are so damned sensitive these days Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
kluce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Depending on the manufacturer, but I have never seen it written over 6 inches. There are some companies that say 5 to 6 inches while some others I have read was written 4 to 6 inches. I've never seen 2 to 6 inches but I can believe one of the manufacturers have it written in the installation manual.
A little off the subject; I normally find that the manufacturer recommends a high loop system to be installed for a dishwasher. I just came across a dishwasher where the installation manual was written that a high loop drain is required for the dishwasher to operate properly. First time I've seen that strong of wording used in an installation manual. |
Only problem is that the customers get ticked when I ask them if I can borrow money. I can't afford to carry that stuff. Robert Sole, CMI 407-637-7288 Florida license numbers HI 169 and MRSA 92 Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties. RobertSole@REMinspections.com Check out my blog orlandohomeinspections.info/ REMinspections.com OrlandoHomeInspector.net |
| Garage door inspection procedure | bgromicko | General Inspection Discussion | 5 | 8/7/09 12:47 PM |
| Height of outlets garage | jmerritt1 | Electrical Inspections | 15 | 10/20/08 11:46 PM |
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 12:08 AM |
| Height Requirement for Line from House to Garage. | mlong | Electrical Inspections | 9 | 4/7/06 9:33 AM |
