What is the minimum height that a service panel should be installed off the floor. Thanks!
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
No minimum.
Only a maximum for main disconnect operating handle. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks! I knew the maximum, I could not find anything on the minimum. I have never seen a panel mounted that low in a garage before.
Handicap accessible.
Keep in mind that, no matter how low the box is located, there must still be a minimum of 6'6" of headroom in front of it. A shelf or other obstruction over this panel would be a violation. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Correct, nothing above
I think it should be high enough so the family dog can't lift his leg on it....
Perhaps a special CMI forum is in order.
Just remember...their is a minimum when it comes to mobile homes. No less than 24" from the bottom of the distribution panel to the floor level of the mobile home [550.11(A)] and when outside 24" from finish grade or working platform[550.32(F)].
So those that inspect mobile homes.....you DO have a minimum height requirement to be aware of....normal dwellings.....not an issue. Paul W. Abernathy |
Thanks! Paul
| Both panels look like the Service panel? | mthiltgen | Electrical Inspections | 6 | 3/4/09 10:09 PM |
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 1:18 PM |
| Zinsco Service Disconnect Panel | pdickerson | Electrical Inspections | 7 | 9/16/06 11:59 AM |
| Service Panel Used As Junction Box | mbazzo | Electrical Inspections | 20 | 8/12/06 12:09 PM |
