Help dating an alecrical panel
Hey guys, I would appreciate it if someone would take a guess or give me any helpul insight as to what the best way to guesstimate when this panel was installed or upgraded. Its in florida, 1961 home, eq loadcenter brand(I.T.E), 150 amp fuse block for the main, and the rest of the breakers are in good looking shape, NO single strand aluminum, Aluminum sevice entry conductors, one aluminum 240 breaker. When did they start, stop using fuses for the main, specially 150 amp main fuse that I have never run into before, nothing over 100 before. Is the combination of main fuse with breakers any clue, is there anything to point me in the right direction of decade, 1961 had 150 amps main?? here is the pic ![]() Thanks you to anyone that can help. dating panels is always a pain for me unless obvious clues are there |
| Need a home inspection in Washington? Check out InterNACHI's listing of Washington certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Posted in another section...
Most likely original but why do you need exact date?
Looks like there are a few comments you can make in regard to cloth conductors,double taps,and wrong color. Nothing wrong with 150 amp service unless you are in process of load calculations which is beyond myself or most Home Inspectors. Point out what you know are issues and let a Sparky do the rest. |
Greg Bell Titusville, Fl 02111507 Serving Central Florida
I think it may have been common to use Buss fuses in the main however. |
Rollie Meyers is a non-member guest and is in no way affiliated with InterNACHI or its members.
The panel is a pre-1968 model (about when the current CTL panelboard standards appeared). The panel pictured has unnotched bus stabs, a later model would have notched stabs in positions allowing twin breakers, so IMO would have to agree that the panel is orig. to the building.
