Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 7/17/06, 9:34 PM
cbarrows cbarrows is offline
Please Note: cbarrows is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Help Determining Reportable Service Size
Hi guys
View picture @ http://www.cthhi.com/defects.htm
Any guidance is appreciated. The listing claimed a 100 amp service however:
1. The distribution panel is rated for 72 amps,
2. The main breaker which feeds the panel is rated for 100amps. I could not open the main breaker box because it was tied shut.
3. The Aluminum service wires entering the distribution panel from the main breaker box appear to me to be AWG 3 or so.
The photo I have attached is blown up to show the true size of the service cables which measure nearly 1/2" wide including the insulation. Yes I noticed the double tap on the service cables.
I reported this as "appears to be 60 amp service" based on the size of the aluminum service wire and the rating on the distribution panel. Here in Canada I believe that 60 amp service for aluminum wire requires AWG 4. If it were a 100amp service the aluminum wire would be required to be AWG 1. Surely this wire is not AWG 1.
What do you think?
Thanks
Craig
Old 7/17/06, 10:04 PM
Jeffrey R. Pope's Avatar
Default Re: Help Determining Reportable Service Size
If the panel was rated for 72 amps with a 100 amp disconnect, that would be a "reportable defect."
The double tap is a big issue. Those conductors surely can't handle the 100 amp potential from the disconnect.
The conductors appear to be tinned-copper rather than AL, and the one on the right (feed from the disconnect?) appears to have been over heated.
Main breaker tied shut? Reportable defect.
The entire system is aged and has been modified by someone other than a professional. Defer all of it. . .
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/17/06, 11:00 PM
Joseph T. Burkeson, CMI's Avatar
Joseph T. Burkeson, CMI Joseph T. Burkeson, CMI is offline
Jeff,
Good catch, very sharp eye, you must have at one time or another work as an electrician?
"I know of no more encouraging fact than the
unquestioned ability of a man to elevate his
life by conscious endeavor." ~ Henry David Thoreau
Certified Master Inspector (2007)
Member, International Assoc of Certified Home Inspectors (InterNACHI)
Member, International Code Council (ICC) - Certified Residential Combination Inspector
Member, American Society of Home Inspectors (ASHI)
Vice President - Suncoast ASHI
Square-One Inspection "Assurance begins here"
Old 7/17/06, 11:06 PM
Jeff
Thanks for the response. What would you report as the service size?
Thanks
Craig
Old 7/17/06, 11:14 PM
The tinned-copper is rated at 100 Amp
Old 7/18/06, 12:10 AM
Actually, no. I've always hated electricity
The rating would be 72 amps based on the panel rating. However, the 100 amp disconnect is improper.
It was probably a 60 amp service at one point and was over-fused by (possibly) the same person that double tapped the conductors.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/18/06, 2:21 AM
Russel Ray's Avatar
Coming home from having a margarita at On The Border, the van in front of me had this bumper sticker:
"Wiring is not a hobby. Hire a licensed electrician."
  • Need a positive networking site? Click here to join Active Rain, a networking community of over 140,000 real estate professionals helping others.
  • NACHI 2005 U.S. Member of the Year
Old 7/19/06, 4:30 PM
Paul W. Abernathy's Avatar
Send a message via AIM to pabernathy Send a message via MSN to pabernathy
Also check that "Grounding" wire that appears to be bonding to the panel case by simply wrapping around one of the screws in the back of the panel....
Paul W. Abernathy,CMI,CEI,CEPE
NECŪ Consultant/Columnist
www.twitter.com/ElectricalGuru
- ICC & IAEI Certified Electrical Inspector
- ICC & IAEI Certified Electrical Plans Examiner
- Look for my article in the Nov/Dec 2009 IAEI Magazine
- 2007 "Top Gun" Winner - Mike Holt Enterprises
" visit www.TheElectricalGuru.com Today !"
Old 7/19/06, 8:12 PM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice clear photos, craig
Stu
Question about Determining Electric Service Size sbelda General Inspection Discussion 2 8/18/07 3:48 PM
Service size and panels ndueker Electrical 7 4/16/07 11:41 AM
Size of service?? cbuell Electrical 4 4/14/07 5:50 PM
Adequate service size....oh, and a GFCI question ksherstobetoff Electrical 13 2/8/07 2:18 PM
Service wire size to breaker panel sfalvey Electrical 12 10/31/06 5:28 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
