Old 4/18/08, 9:05 PM
Kenneth (Kip) R. McCullough, Jr. Kenneth (Kip) R. McCullough, Jr. is offline
Default Help GFCI Tester Showing All Lights
This afternoon during an inspection when I tested an outlet all three lights lit up on my GFCI tester. There is nothing in the manual stating what type of connection this may be. Does anyone know what this means? I've never seen this before.
Old 4/18/08, 9:09 PM
Doug Edwards,  CMI's Avatar
Default Re: Help GFCI Tester Showing All Lights
One would have to know what kind of tester you have. Most of the ones Ive ever seen or own have their own code chart attached. You did not say whether it is a 4 dollar tester or a $300 tester and which brand.
Old 4/18/08, 9:10 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is a combination problem.
Simple as that.
I assume it was fine on the others.
Try checking for ground and reverse with a multi meter.
Old 4/18/08, 9:14 PM
Marc D. Shunk's Avatar
Banned
This can happen if someone has a regular receptacle wired for 240V.
Old 4/18/08, 9:16 PM
It is a cheap $9 GFCI tester from Home Depot. All of the other outlets tested okay. The attahed chart does not show the configuration for all three light coming on. I am at a loss on this one. Thanks for all of your replies.
Old 4/18/08, 10:18 PM
Jeffrey R. Pope's Avatar
Mark is correct. That's the issue exactly.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/18/08, 10:32 PM
Unmoderated Guest
I agree as well.
An improper MWBC with an open neutral and a load can do this.
Old 4/19/08, 1:23 PM
Bruce A. King's Avatar
I just noticed the other day on a new, 120V GFCI outlet, forget which brand, all three lights come on (cheap tester) while holding in on the GFCI reset button.
www.BAKingHomeInspections.com
704 301-3207
Old 4/19/08, 2:11 PM
If your line voltage is on the high side an open ground can light all 3 on a cheap tester. (L/N and N/G lights end up in series). There will be one bright one and 2 dim.
GFCI won't trip by tester rstufflebeem Electrical Inspections 22 3/22/08 9:10 PM
More GFCI info from U/L Greg Fretwell Electrical Inspections 9 12/4/07 9:33 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 1:29 PM
Lights & GFCI Outlets thejnicki Electrical Inspections 14 2/28/07 4:48 PM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 10:31 AM
