Old 12/21/07, 7:57 PM
Greg Keene, CPI's Avatar
Greg Keene, CPI Greg Keene, CPI is offline
Default Help with gounded conductor
Found this on a foreclosure today - This grounded conductor is attached to the hose bid, gas pipe below in pic but wire goes into dirt, not to a ground rod or the gas pipe. This is on front of house, elec supply and main box on side of house, well at back of house. Did not see ground wire coming back up out of dirt at supply - will call it out but loioking for other thoughts.
Old 12/21/07, 8:50 PM
Default Re: Help with gounded conductor
Did you dig around a little to see if there is a rod down there
Old 12/21/07, 9:45 PM
Jeffrey R. Pope's Avatar
Well, if you call it out, be sure and call it the "grounding electrode conductor," because it's certainly isn't a "grounded conductor."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/21/07, 10:15 PM
GEC Information
Old 12/21/07, 10:56 PM
Yes, I dug into the dirt as far as I could (20 degrees outside and lots of frozen ground) could not find a ground rod - thats why I asked for help - wire goes somewhere -
Old 12/22/07, 11:20 AM
I would still guess it was to a ground rod but there are also plate electrodes and ground rings in the code, although you seldom see them in 1&2 family.
Of course it could just be going to nothing.
Old 12/22/07, 5:53 PM
Thanks for the help - wrote it up as a possible concern -just looked strange -
Almost understanding grounding and bonding Ian Gills Electrical Inspections 22 12/8/07 2:18 AM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
