Ryan Brown is a non-member guest and is in no way affiliated with InterNACHI or its members.
I recently bought a foreclosure in Columbia, MD and it was wired with AL wiring (built in 1974). I have already replaced most plugs and switches in the house with AL/CU rated ones, as the previous were all CU only. I have run into a bit of a problem though, and thats for the GFCI's. I am going to need one in each bathroom and then 1 in the kitchen, only problem is I cannot find a GFCI that is AL rated. Do they make them?
If not what is the best way to proceed? Use the purple ideals to pigtail copper and use a normal GFCI. Or use a GFCI breaker for the kitchen circuit and the bathroom circuit? I also found that both bathrooms are on the same circuit which is only on a 15 amp breaker. There is also some plugs in the bedroom that are on that same circuit. That is not code these days correct? Should this be something that needs to be addressed immediately? Thank You |
Ryan,
You will not find a GFI receptacle rated for use with AL wire. You could use a GFI breaker instead. You probably could not fit the GFI receptacle in the box anyway. Be careful working with that wiring. I had quite a few that were broken or broke off just by moving the wires in the box. Current codes would not have the bathroom receptacles sharing circuits with other rooms, except for other bath and powder room receptacles. They would also be on a 20 amp circuit. If you need further help send a PM. |
Am I going to run into any problems with the bathrooms only being on a 15amp breaker and not 20amp?
Why would you put a 15 amp breaker on a 20 amp circuit? Purchase a 20 amp GFCI breaker. . .
Unless he has #10 AL he will be limited to the 15 amp breaker size. #12 AL is only good for 15 amps.
At the time that house was built the requirement for the 20 amp circuit may not have existed. My Code books don't go back that far. |
You're right Jim. I wasn't paying attention
A 20 amp circuit is certainly preferable, but you're limited to the existing conductor size. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
The problem you may run into is that the 15 am is more likely to trip, especially since it is shared outside the bathroom. Blow dryers and curling irons may bring this problem to light.
Thanks for the info, I think the 20amp and 15 amp GFCI breakers will be the best solution as well, esp. since i already have the normal AL/CU plugs purchased.
As far as the normal 15amp AL/CU plugs go, are they pretty safe in the long term? Are they something I should check every year to see how tight the terminals still are? Or would that be overkill? I have read many things about AL wire and it seems like everyone immediatly screams your house will burn down, but if done correctly I assume there should be minimal worries. |
Unless you copalum crimp it, or rewire it, the connections should be inspected on a periodic basis.
Install lots of smoke detectors (I tell this to all my clients......they are cheap protection). |
I never encourage home-owner wiring for this reason. If there's ever a fire in the wall, "Who touched the wiring last?" John Kogel www.allsafehome.ca |
| Meth House? | tallen | General Inspection Discussion | 27 | 4/6/09 7:21 PM |
| Waste line on OUTSIDE of house | gkeene | Plumbing Inspections | 6 | 9/18/07 10:15 PM |
| Radon mitigation system at neighbors house? | jsmith3 | Ancillary Inspection Services & Additional Topics | 3 | 5/20/06 9:42 PM |
