cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
RNC (rigid Non-Metallic Conduit) utilized for ac condensate drain - I need to prove RNC is not rated for a drain application.
I can't find the damn spec sheet for some reason. ![]() and...
This is all I have on it:
"IRC M1411.3.2 Drain pipe materials and sizes. Components of the condensate disposal system shall be cast iron, galvanized steel, copper, polybutylene, polyethylene, ABS, CPVC or PVC pipe or tubing. All components shall be selected for the pressure and temperature rating of the installation. Condensate waste and drain line size shall be not less than 3/4-inch (19 mm) internal diameter and shall not decrease in size from the drain pan connection to the place of condensate disposal. Where the drain pipes from more than one unit are manifolded together for condensate drainage, the pipe or tubing shall be sized in accordance with an approved method. All horizontal sections of drain piping shall be installed in uniform alignment at a uniform slope." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Why would you need to "prove" that an electrical item being used for something for which it was not designed to be used for (a violation of NEC 2005 103B) is improper?
James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Inspecting in Aurora, Branson, Carthage, Granby, Joplin, Kimberling City, Monett, Mount Vernon, Neosho, Nixa, Purdy, Reed Spring, Republic, Springfield and surrounding areas. |
Does anyone see a real problem with this installation?
The NEC doesn't apply as it is not an electrical installation. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I'd be more concerned with the lack of an anti siphon vent tee and riser.
pvc glue can not make a permanent water tight seal when used on RNC (so I've been told numerous times over the years. It's always been taboo to my knowledge. If I'm wrong that's fine ...but I would like to find viable proof either way.
I agree that what ever solvent is used it must be compatible with both materials but there are solvents for this purpose.
Sorry.
Yep!!! |
Well, after talking to 2 LICENSED electricians (licensed through a bordering state) and 1 LICENSED Plumbing contractor - they agree with Brian, they know of no codes/documentation to prevent it but they discourage doing it.
I'm just a deal killer I guess ....well in this instance a hindrance to close escrow seeing as though my client bought the home anyway. Feel free to throw your 2 cents into this. |
Are the pipe and connectors different types of plastic ?, as that may be a problem.
May require different adhesives? |
I'm not sure why you are even asking electricians. As Michael stated, this is NOT an electrical issue.
Your answer is right here: Quote:
I agree, this is not a big deal, but it is not compliant. |
Did you think about contacting the manufacturer of the RNC?
Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE |
