thank you.
Joe,
Thank you and again itod to see you back!! Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nice
I was just coming over here to post this.
I got it second hand from you on the ECN BB. Generac is having a free web cast on generator installations Dec 6 at 1 CST. |
Sign up now! |
Here's an interesting item to be considered for 2011! Section 300.4(G)(NEW) Protection Against Physical Damage; Protection to Outlet Boxes During Construction Add a new subsection to 300.4 to read: “(G) Protection of Outlet Boxes During Construction. The open front of both metal and nonmetallic electrical outlet boxes shall be temporarily covered to protect insulated electrical conductors from physical damage or deterioration due to power routers, plaster spray, spray foam insulation, and other potential damage during construction. The covers shall be constructed of a nonmetallic material and shall be clearly marked “Not for Permanent Installation”.” This proposal was put on “Hold” pending the recommendation of a Task Group made up of members of CMP’s 1, 3 and 9 to correlate the issue during the 2011 Code cycle. Analysis of Change: The intent of this proposal is to protect the box wiring from the effects of router bits during It is interesting to note that CMP #9 rejected a similar proposal during this same cycle.dry wall installation. As mentioned above, this proposal was put on hold until the 2011 cycle. |
I DO make certain my wires are either out of the way, or I use Bradley Construction Blanks. But why should I be forced to cover for someone else's inadequacies in their trade???? How about be make a building code change to force drywallers to NOT have their damn router bits sticking 2" out of the tool???? This proposed change proves my point that no one in this country wants to be held responsible for their actions anymore. Did something wrong? Hell, blame it one someone else! Or...pass some new law to protect you from your own stupidity. |
Speedy....as sometimes happens....what you have is a company that probably submitted this because i noticed in NEC Digest i believe...that someone is making the exact cover being talked about in that proposal......
Paul W. Abernathy |
I like when you get to back charge the drywallers. Some people say it can't happen, but you need to submit the bill to the GC.
tom |
Do they really think that little plastic cover, or a plastic box will stop a carbide router bit? I have a groove in my concrete driveway that says I doubt a rocker would even know he hit it. Other than the noise, I doubt a metal box/cover is stopping a router
"in unfinished basements and in garages and accessory buildings that have a floor located at or below grade level not intended as habitable rooms and limited to storage areas, work areas and areas of similar use."
I'm a bit confused: are "storage areas, work areas and areas of similar use" included or excluded from the GFCI requirements? |
Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
That link no longer works
Did anyone download and save a copy?
| Nick.. You sneeky devil :) | dharris | General Inspection Discussion | 184 | 6/8/07 5:52 PM |
| Extractd from the archives, Thanks Paul for this list! | jtedesco1 | Electrical Inspections | 4 | 1/2/07 7:51 PM |
| Free Software Office type products | bmerrell | Special Discounts for InterNACHI Inspectors | 2 | 12/31/06 11:51 AM |
| Free Office Software Eqiv. For Download | bmerrell | Miscellaneous Discussion for Inspectors | 4 | 12/31/06 11:47 AM |
