Would say anything about this horizontal GFCI outlet under the SPA tub? Would you recommend it be relocated?
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America) |
Looks good to me. Quite typical on this type of protection. It's going to be protected by a jacuzzi cover anyways....Right?
Why would it matter if it is horizontal.?
Is it supposed to get wet down there ,and if it does will it not get wet either way? At least they put it on the hatch side ,which is more than I can say for some of the ones I have seen recently. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
No. Like others said, its OK.
Personally I like the Horizontal install less likely the cord will fall out and create a loose connection from the vibration and cord weight
Thanks!!!
As long as it is secure. Think of how many of these under the spa tubs that you curse at because you have trouble reaching them
as long as it has access Buck...vertical,horizontal,diagonal is fine with Me....
It's fine...as long as it is not in the below locations, you are good to go...
(E) Receptacles in Countertops and Similar Work Surfaces in Dwelling Units. Receptacles shall not be installed in a face-up position in countertops or similar work surfaces. Now I might have a problem with what appears to be the NM Cable not secured properly as it leaves this box...but then again thats me... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 2 | 1/8/11 8:04 PM |
| HELP! What do you call a GFCI outlet technically? | gromicko | Electrical Inspections | 7 | 1/8/09 7:01 PM |
| More GFCI info from U/L | Greg Fretwell | Electrical Inspections | 9 | 12/4/07 9:33 PM |
| Bathroom outlet near floor: GFCI | mthomas2 | Electrical Inspections | 3 | 4/13/07 11:35 PM |
