Old 5/3/09, 11:22 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Hot on Neutral, With Hot Open
I'm using an Ideal 61-059 Sure Test electrical system tester and for the first time have come across the "Hot on Neutral, with Hot Open" indicator. What exactly does that mean? Thanks.
Old 5/4/09, 12:16 AM
Bruce A. King's Avatar
Default Re: Hot on Neutral, With Hot Open
I don't have one of those but deductive reasoning says:
Nothing connected to the small receptacle blade (black wire).
Large blade (White wire) has 120V
Ground ok.
The tester can read voltage with no neutral by using the ground circuit.
www.BAKingHomeInspections.com
704 301-3207
Open Neutral & Open Hot fmagdefrau Electrical Inspections 12 9/18/08 7:04 PM
How do you write up an open neutral mnahrgang Electrical Inspections 7 8/4/08 9:08 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 10:24 AM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 11:19 AM
