Old 12/15/11, 11:56 AM
Roy Drangstveit's Avatar
Roy Drangstveit Roy Drangstveit is offline
Default Hot neutral reverse
I found an outlet, that when tested showed as being a hot neutral reverse.
Then when I opened the panel I found a red wire connected to the neutral buss bar. Does that explain the outlet problem?
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/15/11, 11:58 AM
Joe Funderburk, CMI's Avatar
Default Re: Hot neutral reverse
Possibly, if the white wire was on the breaker. Not really important for you to figure out the reason why.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 12/15/11, 1:53 PM
Here are a few pictures of that panel. There is a white wire on a breaker.Tell me if you see any more problemshot-neutral-reverse-picture-082.jpg
Old 12/15/11, 5:04 PM
Robert Meier's Avatar
The white conductor appears to be part of a 2-wire circuit so it may not be the problem. You would need to inspect further to find the actual cause of the reverse. Removing the receptacle and looking would be the first thing I would do.
Old 12/15/11, 8:12 PM
Jim Port Jim Port is offline
Unmoderated Guest
The white on the breaker is a hot from a 240 volt circuit.
Old 12/17/11, 4:39 AM
Stephen W. Stanczyk's Avatar
There is only one way to test......
Stephen Stanczyk
Old 12/18/11, 10:25 AM
James R. Szczesny's Avatar
James R. Szczesny James R. Szczesny is offline
I tried this but kept getting a weird buzzing feelinf in my body? Are you sure this works Steve?
J.Szczesny
4 Seasons Home Inspections
Washington State Inspector # 711
800 5th Ave #101-385
Seattle, Wa 98104
(206)391-0285
online @ www.4seasonsinspects.com
email @ info@4seasonsinspects.com
toll free cal @ 866-512-9972
"For the best protection,
get the right inspection"
Old 12/18/11, 2:12 PM
You have to lick the fork first....
Stephen Stanczyk
Old 12/18/11, 4:17 PM
Jeffrey R. Pope's Avatar
Shows how much you know. You have to insert the fork while holding it in your mouth...
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/19/11, 10:32 AM
William T. Misegades William T. Misegades is offline
And using a plastic fork won't work as well either. I always recommend stainless steel.
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Old 12/19/11, 12:56 PM
Christopher Currins's Avatar
Good tip.
Christopher Currins
Certified, Licensed
Old 12/19/11, 1:26 PM
I recommend silver since it's the best conductor.
Old 12/19/11, 1:47 PM
So those born with a silver spoon in their mouth must be plumbers?
Stephen Stanczyk
Old 12/19/11, 4:32 PM
Aubrey J. Kahn Aubrey J. Kahn is offline
Don't forget for best results be sure to stand in a 5gal bucket of water while testing.
Old 12/20/11, 1:30 PM
Michael Ardai Michael Ardai is offline
Please Note: Michael Ardai is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like there's a pair of thhn wires leaving the panel on the upper right. Not related to the reversed outlet, but still wrong...
/mike
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Reverse Osmosis phinsperger Plumbing Inspections 3 10/30/07 6:28 PM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
Proposed Definition of Neutral Conductor and Point jtedesco1 Electrical Inspections 1 4/22/06 10:19 AM
