I completed an inspection on a 33 year old house with aluminum wiring. Before opening the panel, I used my "Ciruit Alert" and covered all four corners of the panel box. I was leaning on a chest freezer directly in front of the panel. The alert indicated a current. I was surprised and tested the box again. This time I did not make contact with the freezer. The alert indicated no current. I have had the unfortunate experience years ago of going dead to ground and woke up in the hospital. In this case I declined to inspect the electrical and wrote up that a licensed electrician should be consulted.
Comments Please. Bryce Jeffrey |
Your call, and probably the right one. When in doubt, err to the side of caution. Chances are pretty good you would have had to defer some items to an electrician anyway with the presence of aluminum wiring in a 33 year old home. No telling what you would have found behind the cover panel.
I totally agree about deferring a home wired with AL branch circuits, but relying on a "no-touch" tester in this case is a bit reactionary IMO.
Those things are notorious for false positives. Heck, if you rub those things againt your shirt you get beeping. Also, your tester indicates voltage, NOT current. |
I used to do that to my apprentices and tell them that they're full of potential. Jeff |
Petey,
You got that right..I got a Greenlee that will chirp off my hand sometimes. I have a couple others less sensitive. Last edited by dedwards; 7/29/08 at 11:37 PM.. |
gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Too funny! We just send ours to Tim Hortons. |
Yes, I think you made a good choice! by deferring to a qualified Electrician.
Eragorn Northe Der Hous Inspector LLC Certified Home Inspector Mobile - 306.684.1748 www.derhouseinspections.com |
Amy, are you really from Moose Jaw?
I LOVE that name! TRIVIA: Do you know the cinematic signifigance of it? What film was it mentioned in? |
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 10:59 PM |
| Panel Inspection Safety | roconnor | Electrical Inspections | 10 | 9/24/06 10:02 PM |
