Old 8/26/13, 3:33 PM
Nick Lemaster Nick Lemaster is offline
Please Note: Nick Lemaster is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Hot tub breaker
I have an exterior breakaway panel to a hot tub that had a 50-amp breaker that has started to trip after 4 years. There is a 50-amp breaker in the main panel. Was advised by the hot tub company to change the outside to a 60-amp but nothing said about changing the inside. Is this a good idea?
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/26/13, 3:52 PM
William T. Misegades William T. Misegades is offline
Default Re: Hot tub breaker
The maximum breaker amperage should be noted on the hot tub pump, you should not put anything higher. The circuit conductor should also be sized/rated for that breaker installed.
Where there is a Will there is a Way!
Will Misegades
TREC# 10465
RedFish Home Inspections
www.redfishinspections.com
Infraspection Institute Certified Infrared Thermographer Level I # 9631
"it's not just about how to turn on and tune the camera to make pretty colored spots!"
David A. Andersen, Woodlawn, TN
Old 8/26/13, 4:20 PM
Jim Port Jim Port is offline
Unmoderated Guest
The tub needs to be repaired. Following the store advice could create more issues and ignores the problem.
Old 8/26/13, 4:30 PM
Christopher Currins, CMI's Avatar
Christopher Currins, CMI Christopher Currins, CMI is offline
If there were no previous issues with the breaker tripping, then it started tripping after 4 Years, apparently something is wrong. My advice is to call a qualified electrician. This could be a very serious safety issue.
As Will said the maximum breaker size is listed at the pump/motor and the conductors need to be the correct gauge listed for the breaker that's protecting them.
CBC HOME INSPECTIONS
Christopher Currins
Professional Home Inspector In Edwardsville, Glen Carbon, Godfrey, Maryville,
Fairview Heights, O'Fallon and surrounding areas of S
outhern Illinois
We Make It Safer
Old 8/26/13, 4:49 PM
Paul W. Abernathy, CMI's Avatar
Paul W. Abernathy, CMI Paul W. Abernathy, CMI is offline
Send a message via Skype™ to pabernathy
I agree, the unit needs servicing or it could be as simple as moisture in the 50a disconnect enclosure. Interesting enough, if the branch circuit itself is protected by a 50a breaker this should offer the protection to the circuit . Without more details the 60a would possibly serve as a supplementary OCPD. However, something needs looking at and never follow the advice of the HotTub manufacturer when it comes to the electrical components.
Can we assume GFCI protection on this HotTub?
Paul W. Abernathy
NFPA 70 (NEC) Code Making Panel 17 Committee Member
UL 62 Committee Member
https://www.youtube.com/watch?v=-WBi4bXeNeQ
“Promise me you'll always remember: You're braver than you believe, and stronger than you seem, and smarter than you think.” -RIP Dad, Love You!.10/10/2014
Disclaimer - All my posts on this forum are of my own personal opinion and in no way represent the opinions of Encore Wire, or other associations, organizations or affiliations.
Robert Meier's Avatar
Robert Meier Robert Meier is offline
As stated there is a problem with the tub. Regarding the size of the OCPD as long as the breaker at the beginning of the circuit is sized properly the one at the tub can be larger and would act merely as a disconnecting means.
Old 8/26/13, 9:04 PM
Yes, there is GFCI protection on the hot tub.
Old 8/26/13, 9:40 PM
Um...lol...didn't I say that...
Paul W. Abernathy
Old 8/27/13, 4:39 AM
You: 8/26/13, 4:49 PM
Me: 8/26/13, 4:49 PM
Yup.
Old 8/28/13, 2:43 AM
David A. Andersen's Avatar
No you can not!
Nick, just change out the breaker with the same size and type (GFCI). Or get a service call to check the equipment. It could be a light, heater, motor ......
"working together to get-IR-done" Chris Walsh
Bracebridge, Ontario:
BPI# 5015804
Old 8/31/13, 10:55 PM
LOL...our minds are melting into one big mass of Electricalness Robert.......we post as ONE!
Paul W. Abernathy
Location of main breaker in panel mraumikaitis Electrical Inspections 16 2/19/13 2:16 PM
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
Main panel...recommendation ? dnasser Electrical Inspections 6 11/22/09 9:55 PM
Electrical Guru Question? Breaker lock outs pdoane Electrical Inspections 4 9/7/07 2:05 PM
