A friend is installing an outdoor hot tub/spa and I have a question. All of my training (that I can remember
NEC 680.71 Hydromassage bathtubs and their associated electrical components shall be protected by a ground-fault circuit interrupter.
Jeff, isn't that strictly for the indoor, bathroom type of hydromassage, 'jacuzzi' bathtubs? The one in question sits in a new deck 30' away from the main house.
I missed the outdoor part sorry.
680.62 shows the requirements for outdoor installations. Basically, GFCI protection is required at the receptacle or "outlet" supplying power to the spa. Not required if protection is "built-in." Not required in three phase, or over 250 volts with a >50 amp heater capacity. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 1/10/06 at 2:24 PM.. |
Prior to 2002 field assembled spas with hard wired equipment did not need GFCI. Self contained spas do.
In 2002 they expanded that to all spas unless they are part of the pool, sharing the bonding grid or if they have >50a heaters or 3 phase. |
What year did the indoor jacuzzi tub gFCI's start being required? Thanks.
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Wow...you sure pulled up an old thread there
Paul W. Abernathy |
Thanks for the PDF Michael. And Mr. Peck for putting it together.
Darin Redding, CPI Housecall Property Inspections san diego home inspection rental inspection | warranty inspection Facebook Like darin@sandiegohomeinspect.com 619-663-8740 home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista. |
If he's hardwiring it then your going to need a disconnect anyways so get one with the GFCI built in. They are available at Home Depot or Lowe's and are not that expensive. Better yet hire an electrician. The question I have is why would you even question the need for a GFCI when your mixing electricity with water your sitting in?
When your friend puts in the disconect - it needs to be with in sight of the spa, no closer than 6ft and no further than 50ft.
5144 Atwood Terrace Inverness, FL 34452 352-212-3576
You do know I posted that question 6 years ago, right?
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| GFCI Safety Notice | rcooke | Electrical Inspections | 1 | 10/30/07 12:29 PM |
| The question asked on the new HI Study test here? | jtedesco1 | Electrical Inspections | 28 | 10/4/06 9:31 AM |
| UL Information about Testing of GFCIs | jtedesco1 | Electrical Inspections | 0 | 2/5/06 4:38 PM |
