Old 7/20/08, 10:04 PM
Peter W. Bennett Peter W. Bennett is offline
Default A Hot Wall
Voltage indicator went off light a Christmas tree.
1870's home suspect knob and tube (none visible) with remodeled bathroom that has wire lath and plaster wall. OUCH
Old 7/20/08, 10:15 PM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Default Re: A Hot Wall
good catch
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 7/20/08, 10:57 PM
mnahrgang's Avatar
Peter, 2 questions...
How did you detect the voltage in the wall?
What made you check?
Mark Nahrgang
www.HeyMark.info
Old 7/20/08, 11:00 PM
Michael Larson's Avatar
And did the GFCI test normal?
Michael Larson
Hudson, WI
[/I]
Old 7/20/08, 11:45 PM
Marc D. Shunk's Avatar
Banned
This is interesting, but I think there's at least a 50% chance that no problem exists.
Old 7/21/08, 1:01 AM
Jeffrey R. Pope's Avatar
Our voltage detectors will go off when you get close to energized NM - that doesn't mean that a defect exists, it just means there are energized components in the area.
If you could get indications from a voltage meter, then I would be concerned.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/21/08, 7:06 AM
Carl A. Brown's Avatar
Hit a wire with a fastener!?
Old 7/21/08, 7:36 AM
The GFCI protected outlet polarity was acceptable, and tripped off with the internal tester, and my device so it tested normal.
When the device was in the off-open circuit position, I put my voltage indicator in the two prong wall light fixture over the sink. The outlet was still on. As I moved the voltage indictor from the fixture to the GFCI device, accidentally along the wall, I noticed the wall issue.
I then checked other areas ( per the photo )
I did not have anyother equipment with me to check the wall, plus I could not inspect the load center as the screws were rusted. Recommended a licensed electrician evaluate this condition and the entire electrical system and conduct all necessary repairs.
I remember reading a post about a fastener through a wire and how the whole wall was hot, well, I think I finally found one to.
Old 7/21/08, 8:53 AM
Never put your trust into a tick tracer... there are many variables that can cause them to give a false reading. Just by moving it across a surface, the vibration can set the thing off. They get old and 'oversensitive'.
Old 7/21/08, 8:55 AM
The voltage detector I have blinks and alarms if AC it detected.
If it is static or DC the sound will not alert.
Paul Abernathy sold them a while back and with NACHI logos on them.
Here it is sans logo.
No switch to leave on or where out. Best of this type I have ever owned.
Michael Larson
Hudson, WI
[/I]
Old 7/21/08, 7:31 PM
Yep....The ones I had were the best. I kept a few for myself.
Paul W. Abernathy
Old 7/21/08, 8:27 PM
Banned
They may have fed the properly wired and working GFCI receptacle from this location. There would still be voltage on the wires even though the GFCI had tripped.
This would be the still energized wire feeding the GFCI.
The other postive signal could be another wire feeding some other device/circuit or going up to a light from a switch in the room (if one) sharing a common wall or etc, etc, etc.
I'm with M. Shunk on this one. There are signs of proper wiring at the GFCI recept......just how far does this extend??
Old 7/22/08, 11:42 AM
Yes, I know that. I actually place the indictor on the wall, going very slowly.
Thanks,
Peter
Old 7/22/08, 12:34 PM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
Peter try moving it slowly on any wall surface you may be a bit surprised. I'm more at a %5 chance of anything being wrong but keep us posted.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 7/22/08, 8:17 PM
Sadly, I am reminded of this accident where the metal studs were energized. Read the story and see the video below:
http://www.nachi.org/forum/f19/person-electrocuted-energized-metal-building-1914/
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
No Brick Ties - Wall Buldge Stew Structural Inspections 1 4/22/06 6:56 AM
