Old 12/5/06, 2:35 AM
Justin Watts Justin Watts is offline
Default Houses with AFCI Breakers.... Basic testers shut off AFCI breakers?!?
Hi Guys,
I have inspected a few homes where my GB Surewire tester, just placing the tester in the bedroom outlets has shut off the AFCI breakers at the panel..... I am assuming that the AFCI breaker is doing its job?!?!
I wasn't sure if this was a normal condition, since I am (only) placing the tester in the bedroom outlet, and (not) pressing my "GFCI" test button...
Is this normal????
Old 12/5/06, 2:49 AM
Paul W. Abernathy's Avatar
Default Re: Houses with AFCI Breakers.... Basic testers shut off AFCI breakers?!?
Hmmm......AFCI's and testers are in their infancy still......but my AFCI tester does not do this so I would tend to say in my opinion it is not normal that it would trip it without even pushing the test button for it.
It could be a bad tester and the AFCI is detecting it.......wish I could tell you more but I would only be speculating at this time.
I will try to do a little looking around for more information or others may have some "Proven" facts...not assumptions I hope.
" Infancy" - compared to other technologies, but Square D has been working on them since back in the 80's....but only recently accepted by the NEC...and it is changing all the time.
Paul W. Abernathy,CMI,CPI,CME
Old 12/5/06, 8:32 AM
wsiegel wsiegel is offline
I have been told that the only correct way to test AFCI breakers is to turn them off at the breaker (with the test button) and then go to the room and make sure that all the outlets and switches have no power.
Old 12/5/06, 9:41 AM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
I do this as well...
I used to use the AFCI button on my 61-058 but it didn't always work...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 12/5/06, 9:54 AM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
Whats "arc" vs "ground" and why a bedroom vs the living,family,dining,kitchen rooms?
Remember to please answer in HI language vs elect.
Thanks...
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 12/5/06, 10:07 AM
This is correct, the proper approved method for testing GFCI's and AFCI's are at the receptacle or breaker depending . Now, many will use the testing devices as a backup or secondary testing method and that is fine....but as stated you should first test in the manufactures intent and that is at the breaker or receptacle...again depending on which you are speaking of.
This is also a way to ensure in new construction that the EC complied to the issue of no outside plugs are also connected to the bathroom GFCI circuit....and so on......when you trip the GFCI's lets say...on the outside of the house...check the bathrooms also to ensure they are still working....you will be amazed that many EC's still dont know about that change.
Old 12/5/06, 10:13 AM
Mark,
I have to run to a job but I will be brief....
An ARC is a static connection between two points that over time will heat up due to a poor connection...I am sure you have seen an ARC happen in a science project or on TV....
It is basically electricity jumping from one point to another....the contacts are so close but not touching...the electricity JUMPS accoss to the opposite side....thats basically an arc.....without more detail.
A ground is the connection and intential or accidential connection to earth.....or some body that is assuming the place of earth...
Why the bedroom...well considering you spend the most time in the bedroom unaware of your surroundings ( sleeping ) this is probably the main reason...studies have shown that most fires start in the bedroom.....basically you are in their the most....and unaware the most unlike other areas.
However, it is being debated right now to add to the NEC that all 120V 15 & 20 branch circuits be on AFCI*......also I believe the bedroom was the start.....but it will probably not be the ending point of this AFCI debate.
Sorry....originally mistyped GFCI...my BAD
Old 12/5/06, 10:58 AM
However, it is being debated right now to add to the NEC that all 120V 15 & 20 branch circuits be on GFCI......also I believe the bedroom was the start.....but it will probably not be the ending point of this AFCI debate.
I believe Paul meant AFCI, not GFCI
Old 12/5/06, 11:02 AM
opps...yep I did mean AFCI....thanks......
Old 12/5/06, 5:39 PM
It is already in the draft of the 2008 code to make all 15 and 20a outlets AFCI. The only debate is whether they should change it or modify it. We may see some exceptions but I bet it will happen.
Old 12/5/06, 5:45 PM
ldapkus ldapkus is offline
Here's some info on AFCI's.
http://www.cpsc.gov/cpscpub/pubs/afcifac8.pdf
Old 12/5/06, 8:22 PM
bsumpter bsumpter is offline
I was in a two year old SFR a couple of weeks ago. The sub was in the laundry room, and when I pushed the test button for the master bedroom afci, the ceiling light in the laundry went out...
Hmmm...
Brian R. Sumpter
First Call Inspections
Proudly serving most Bay Area Counties
www.firstcallinspections.com
Old 12/5/06, 9:03 PM
The question is whether all the power went out in the bedroom. Nothing says the bedroom circuits are dedicated.
Old 12/6/06, 8:52 PM
thanks Linus!!!
Old 12/6/06, 8:53 PM
Good info Paul!
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
Can an AFCI offer GFCI protection gbeaumont Electrical Inspections 19 7/7/06 12:45 AM
