Old 1/9/08, 11:45 PM
Jeffrey R. Pope's Avatar
Default How's this for a 240V Circuit
I'm sure it seemed like a good idea at the time. . .
hows-240v-circuit-p1090006.jpg   hows-240v-circuit-p1090008.jpg   hows-240v-circuit-p1090007.jpg
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/10/08, 12:04 AM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: How's this for a 240V Circuit
I'm speechless
Old 1/10/08, 2:00 AM
I'm not shocked ... but I am 3000 miles away.
Get closer at your own risk
Old 1/10/08, 3:29 AM
Christopher Currins's Avatar
Another good reason to shut off the main before you remove the cover.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 1/10/08, 4:22 AM
You actually disconnect the main?
Have you ever experienced one that would not reset if it was a CB, especially an old federal?
Old 1/10/08, 6:23 AM
Roy D. Cooke, Sr's Avatar
I do not think this is a very good idea to say this as many newer HIs might think they should.
If you feel it is necessary to shut down the Main power then Just possible you should
(A) take some more electrical courses to see what the many repercussions could be .
(B) Take some more electrical courses to Lean how to properly inspect a home
(C) just do not inspect the service in a home.
My thoughts others might disagree ..
...Cookie
Old 1/10/08, 8:23 AM
...Cookie
Ditto
Abraham Lincoln
Old 1/10/08, 1:36 PM
I have never turned off the power to inspect the service equipment. I don't intend to change my practice. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/10/08, 3:06 PM
David C. Macy's Avatar
I wanted to shut off the power to this home as the previous owner damaged as much as he could before he left.
My client was about 2 inches from contacting live wires.
I had to shut down the water as when it was dewinterized a few hours before my inspection there was a burst pipe behind the tub and they had left the exterior faucet on.
I thought covering the SEC with the vinyl siding was a nice touch.
ID:	17347   hows-240v-circuit-110908-037-small-.jpg.jpg
Old 1/10/08, 4:31 PM
I guess I need to write this different.
Turn off the main disconnect before removing panel box cover.
Christopher Currins
Certified, Licensed
Old 1/10/08, 7:15 PM
I think we understood what you meant Christopher, at least I did. I have never intentionally turned off any breaker in order to inspect a panel.
It would be inappropriate to do so. Even if an obvious hazard exists, it's not wise to turn off the main disconnect for purposes of the inspection. If the panel is unsafe to access, you just don't access it.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 1/10/08, 9:16 PM
lfoster's Avatar
lfoster lfoster is offline
You think these folks were p.o.'d about moving?
Old 1/10/08, 11:25 PM
...Cookie
I made my statement concerning shut off main breaker because that is what the home inspection educator taught us. I am not an electrician, but I have completed 2 years of vocational electricity which I received an A grade. Even though that was 15 years ago. I have installed a few new services, the last picture is a recent one of a property I own that was inspected by a licensed electrician before the electric company would connect to it. Here are pics. of my Electricity Study Book. Note two places: shut off the main disconnect, and remove the inside cover and
WARNING: Before removing a panel box cover, be sure to observe electrical precautions. Turn off the main disconnect before removing the panel box cover. I admit I have changed many fuses and installed new breakers without shutting off main breaker. I was assuming, being taught this by my instructor, to be a home inspector thing. Even though I rarely do it, but I have. Especially when a client is right next to me and I can't get them to back away.
Christopher Currins
Certified, Licensed
Old 1/11/08, 12:30 AM
cduphily's Avatar
Jeff, May I borrow your pictures for my next chapter meeting?
Old 1/11/08, 12:36 AM
cduphily's Avatar
Like this one ... yes that's moisture on the cover and dripping out and around every opening. Actually going to reinspect this panel in its NEW LOCATION tomorrow morn. Which means I'm out of the house at 5 AM Night ALL!
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
Article 240 : Overcurrent Protection Article pabernathy Electrical Inspections 0 5/23/07 12:40 PM
Can an AFCI offer GFCI protection gbeaumont Electrical Inspections 19 7/7/06 12:45 AM
