Just finished an inspection today. LOTS of moisture in the attic. Happened to bump a luminary under the insulation and took some pictures (attached). Doesn't appear to be IC rated or if it is, it wasn't properly installed since the interface of the luminary and drywall was not sealed.
I did a look-up on the UL label (E17885), but that wasn't any help. What do you think? Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It should say it somewhere on the interior label of the fixture. If you look at the junction box on the side of the fixture is the thermal overload sticking out of it? If so I would bet that it is not an IC type.
I didn't see anything. Considering the j-box is not sealed I would guess no. The only rating I saw was for damp location and suspended ceiling.
AFAIK IC rated does not require sealing the drywall housing interface. I have never seen this for the brand I typically install. IC just allows the insulation to contact the housing.
I think the information you may need is on the label on the outside of the housing. If you could see the model number and brand on the inside label it would help. |
I just attached the outside pics
There are two methods to determine.
Check like you did for the IC rating and also check for air slots that would tell you they are not. From what I see they are IC rated.
Were you getting good air flow in the attic from roof/soffit,ridge vents,gable,etc.? I swear that sheathing looks like it was stained.(as in varnish) www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 3/1/11 at 5:13 PM.. |
No, Some of the soffits were covered with insulation. There were 4-8 inch roof louvers. 1120 sq feet. 3.7 sq ft vent area required. 1.87 sq feet on roof which is just over 4 louvers. One additional roof louver and installation of air chutes is what I recommended in the report.
That is a Commercial Electric unit manufactured by Jimway and distributed by Home Depot. According to what I found out, it is an IC rated can. Jimway / Commercial Electric Non-IC cans are cream colored and their IC rated cans are the galvanized color. There would have been a label just past the interior frame that holds the plug / fixture.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Thanks. I couldn't get in that far without disassembly which is going beyond the SOP. There was an Energy Code sticker on the inside issued by the state of Washington. It was the green one in my original post.
Just a note that IC is a different rating than AT (air-tight).
Why would the junction box need to be sealed? There is no interface to the conditioned space. |
Is type AT listed somewhere? I saw type IC listed in NEC 2008 410.116.
It may be IC approved and loose to air movement......... it can't be airsealed on site for energy conservation and prevention of moist air migrating to the attic. It was tested and approved in its "loose" state and must remain that way to maintain its "tested/certified" status.
Go to HD and look at the can lights next time. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Fire Rated Garage Door | ederousse | Structural Inspections | 5 | 12/10/10 12:35 PM |
| Fire Rated Assemblies | mcyr | Commercial Inspections | 2 | 8/29/10 8:28 AM |
| Fire Rated Garage Door? | jfunderburk | Interior Inspections | 3 | 7/21/07 10:01 AM |
| Door to Attic. To be rated or not? | jlybolt | Interior Inspections | 8 | 6/1/07 1:04 AM |
| Manablock in rated wall | jlybolt | Interior Inspections | 10 | 5/23/06 9:27 PM |
