First picture of tester at washer outlet with washer pluged in.
Second picture of same outlet with washer unpluged. ??????????????????????????? Last edited by bkelly2; 10/15/08 at 5:34 PM.. |
This one is easy
Ground is being supplied by the washer rlb |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Be careful with any of the circuit testers when something else is plugged in. As RLB said: the washer is supplying the ground.
1950's house and quite a few open grounds and nuetrals and hot's reversed. |
I really think we should be using a more sofisticated tester than the old $7.96 tester in Home Depot.
This same problem exists at any socket on a string of sockets
They can test good when the are not based on something that might be pluged in at some other socket on the string rlb |
You got me beat on the ladder. I have a $100.00 folding ladder and a $225.00 28 foot ladder. WAIT an minute. That means I have you beat.
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Since my 3 bulb tester told me they needed an electrician, what would the Tri-Corder pictured have told me? To capitalise Electrician?
William asked for a much more sophisticated tester, so I posted one. If you feel an Electrician is needed on a specific building, simply recommend one. |
I asked a question about what the tester pictured would have told me that the 3 bulb tester did not . If you feel the need to answer statements instead of questions............... David I currently do not own a sure test and have recently been considering one. I tell what I'll start a new thread debating the the two and see what comes of it. Last edited by bkelly2; 2/8/07 at 10:33 PM.. |
Now I can't wait till Sunday when I will try to duplicate that test on my workbench. Brian, was the center lamp brighter or is it just the photo? |
Brian, what kind of flashlight do you use? I am a serious flashlight nut. These are my favorites, I keep an E1 in my pocket at all times, small as a roll of lifesavers, more power than a 4-D cell light. www.surefire.com
| Light Bulb Clearance | pdickerson | Electrical Inspections | 10 | 8/30/07 8:44 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 8:22 PM |
| Brilliant idea | jmichalski | General Inspection Discussion | 45 | 11/14/06 8:19 PM |
| Light Bulb Savings Calculator | swaskewicz | General Inspection Discussion | 0 | 11/11/06 11:11 AM |
| How many forum members to change a light bulb? | kshepard | Miscellaneous Discussion for Inspectors | 9 | 8/2/06 10:56 AM |
