Carrie Kirscht is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am not an inspector, just a concerned homeowner...
Last night I was watching a home show where an inspector cautioned a buyer about an FP box (going as far to say that it would be difficult to get insurance). Sitting here today, I realize that I also have an FP stab-lock box. I've done a great deal of reading this morning, and realize that there are many unofficial warnings. I am leaning toward replacement, though I have never had any sign of a problem. I believe that this a 125 amp box, installed in 1981. Looking for your professional opinion and experience--would you replace this if it were in your home? Thank you! |
I can tell you from first hand experience that FPE breakers often fail to trip when they should. I am an electrician, and my professional advice is to have the panel replaced. After all, overcurrent protection is one of the main reasons for breakers, and the FPE often does not live up to that requirement. The fact that you have no sign of a problem is meaningless. You have no way to know if your breakers should have tripped in the past and didn't.
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
FP boxes have concerns. However if there is no indications of issues leave it alone.
However if it where my house. I would call a local licensed electrician who has a good reputation and ask for a quote to replace it. If the quote was within my budget, it would be on his schedule to replace that day. hope this helps, Curt |
Are you running for office or going bipolar, on us? Carrie, Follow Marc's advice he is a well respected source of A+ information and I advise my clients of the need to have evaluated whenever I encounter FPE. Here is an example of a different type panel that had gone undetected until I showed up for an inspection. Note the fused marks on the bus bar, never seen under the breakers and the current owners never disclosed any problems. Why would they they were also unaware. Not if, but when was this going to become property or life loss, issue? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/30/08 at 8:22 PM.. |
Its one of those rare instances where both answers work. You have issues easy to say replace. I am no fan of FP but if there are no issues its hard as a HI to say replace....easy as a HOME OWNER to say replace.....hence my answer. Curt AKA soon to be running for office.....Not |
The Canadian FP I do believe are different then USA. They are no concern here and are still manufactured and I have one in my home . I am not changing it . ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I'm of the school of thought that says HI's are not qualified to determine the need for replacement hence my standard report wording is:
If it was my home it would be replaced, too. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
If there were documented issues regarding the airbags in your car, would you say the same thing? After all, they've been there for X# years and there has never been a problem. . . That's most likely because you've never had to rely on them [airbags or breakers]. The panel and it's components are a safety system, much like the airbags in your car. When there is a problem, you want your safety systems to work flawlessly. Otherwise, the results could be catastrophic. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Carrie,
Like Marc I am a licensed and insured electrical contractor. When I bought my home in 1993 it had an FPE panel that was in fine shape physically. I replaced it within one week of moving in. Does that tell you anything? |
Carrie, I also always reccommend immediate evaluation by a licensed electrician. As an HI we can't really say something must be replaced. If it was my home it would be replaced ASAP. you may want to cruise around on this site. http://www.inspect-ny.com/fpe/fpepanel.htm
| IR In The Market Place | jmckenna1 | Thermal Imaging, Infrared Cameras & Energy Audits | 4 | 12/18/07 6:43 PM |
| Home Inspector Listings Part Two | jbowman | Miscellaneous Discussion for Inspectors | 8 | 8/29/06 8:52 PM |
