I would like to ask about the following for a Ryan home built in 2004.
Some pertain to electrical but some are for other areas. This area propably gets the most views so I thought I would post here. 1) The front GFCI had a waterproof cover but the back just had the metal cover. What year was the bubble cover required? 2) The interior cover of the air conditioner disconnect box was missing. Is it require to have a interior cover? I think so as the wire and terminals can be contacted. 3) Is a gas water heater required to have a bonding wire when the home is done in CPVC supply. Also why are some heaters bonded with just the water line and some with gas. 4) There where no H clips installed at the sheathing and Ryan homes says they seal the house attic so the home owners can not access. I find this to be unusual and noted to inquire with the builder.(I used the picture That GB had in the roofing course) 5) The sump or sanitary was sealed in the basement. How do you change the pump or test the pump as the owner? (See picture) 6) When did they start requiring that the condenstae to the drain be selaed? 7) What is the correct distance for the gutters to slope to the downspout? There was evidence of ponding & debris. Only sloped like a inch for about 20 feet. (See picture) Any comments on the stair repairs? (See pictures) Thanks for answering my questions. Have a great holiday. Dave |
Even among inspectors/electricians you can get a fight started about bubble covers. If they had a snap cover, would simply note that "unattended" plugs should get a bubble cover.
The water heater should be bonded to the EGC of the igniter circuit. If it is a pilot light model with no electric connection it is OK without bonding on a PVC system. Sealing the attic may be OK but there can't be any boxes up there with covers on them. |
If you look carefully at the cover for the basin for the submersible sewage pump you will see screw or bolt heads that allow the cover to be taken off to service the pump inside.
On the stairs,
Looks like they removed the original threads from the stringer...Note the "slots" where most likely where the original thread where inserted.. Now "glued" heavily with small pieces of 1 by stock to make up for large gap????.. Shims?? These guys found it easier to glue the snot out of every thing. Instead of completely replacing stringer it must have been cheaper to do this.. I question the strength of the threads and weight (live load ) capability.. Guess the only way you get to stop squeaks is by using PL 400 in large quantities... Did you get a size idea on the threads?? 1x10 |
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Hope that helps ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
A strong and squeakresistant stair can be accomplished through the combination of routing, wedging and gluing…granted, that’s a sloppy job but the theory was attempted.
scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
I dont think they go through the trouble of routing and gluing in a Ryan home, they are generally a cheaper home. Also the risers appear to be Plywood, the grain looks like plywood, and isnt that a stamp?
Steve |
Once saw Norm on this old house use the same tapered groves, wedges and glue. This is a stair system.
| Plumbing codes | Al G. Liminator | Inspecting HVAC Systems | 1 | 10/14/07 8:12 PM |
| Egress code | prussell | Exterior Inspections | 79 | 6/16/07 8:54 AM |
| New Home Inspections | jbreazeale | General Inspection Discussion | 23 | 5/11/07 10:29 AM |
| Announcement: Verify/Submit Zip Codes | teaton1 | Miscellaneous Discussion for Inspectors | 0 | 4/13/07 5:08 PM |
| T-Stat codes ? | nkienitz | Inspecting HVAC Systems | 6 | 3/1/07 11:37 AM |
