Old 7/11/08, 7:54 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Inspector and electrician opinions on these situations
Want to ask inspectors on how they report on the following and electrician how the address these issues.
1) Home has GFCI's that are not grounded.
2) Presence of knob & tube wiring. Home has an updated panel with mostly 20 amp breakers.
3) Ungrounded system. 2 prong receptacles throughout. Home has a window air conditioner.
4) Home has no AFCI. Home is older then 2002.
5) Sump is on a grounded duplex receptacle shared with other circuits.
6) Home has old style light fixtures above sinks with receptacles.
7) Home has a round meter base with 100amp SEC to 100 amp breaker.
Older system with no GEC.
9) Home has a grounded system using a green insulated ground connected to homes water supply system.
10) Air conditioner manufacturer's spec state max fuse/circuit breaker 30amps. 40 amps fuses at exterior shut off/30 amp circuit in panel.
Would like opinions from inspectors and also electrician that are called to home to review above items.
Just curious as some of these items have difference of opinions.
Thanks for the time
Old 7/11/08, 8:11 PM
gbeaumont's Avatar
Default Re: Inspector and electrician opinions on these situations
Hi Dave
Here's my random stab at reality
They'll still offer some protection and therefore better than nothing.
The K&T realy needs to go
Many modern electronics require a grounded receptacle, system badly out of date.
No big thing by itself, and no doubt we''ll eventually be recommending AFCI's as we do for GFCI's, should be installed when the wiring is replaced.
Prefer to see it on either a dedicated circuit or at least GFCI protected
Was Ok back in the day now requires upgrade and GFCI protection
PoCo may have allowed that
See above
Not a problem as long as supply is metal, but along with a general upgrade I would hope to see a second driven rod installed
The 30 amp in the panel will blow as needed so the 40 disco is redundent
All of the above realy points to a home with 70 year old wiring that is in dire need of an up-grade.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 7/11/08, 8:23 PM
Marc D. Shunk's Avatar
Banned
Here's your comments, from a sparky:
1) Home has GFCI's that are not grounded. Probably legal if they were just updating an old 2-wire system. Good idea, in fact.
2) Presence of knob & tube wiring. Home has an updated panel with mostly 20 amp breakers. Legal, if that's #12 K&T, otherwise a hazard.
3) Ungrounded system. 2 prong receptacles throughout. Home has a window air conditioner. Legal wiring, improper connection of window shaker
4) Home has no AFCI. Home is older then 2002. Legal
5) Sump is on a grounded duplex receptacle shared with other circuits. Legal, but ill advised
6) Home has old style light fixtures above sinks with receptacles. Likely legal at the time, but a present known hazard.
7) Home has a round meter base with 100amp SEC to 100 amp breaker. Probably okay unless you have more information than that.
Older system with no GEC. At risk for excessive lightning damages.
9) Home has a grounded system using a green insulated ground connected to homes water supply system. Not enough information to comment yet.
10) Air conditioner manufacturer's spec state max fuse/circuit breaker 30amps. 40 amps fuses at exterior shut off/30 amp circuit in panel. That's essentially a 30 amp circuit then. The smallest breaker will trip, which is the 30.
Old 7/11/08, 8:47 PM
Thank you
I value your opinions
Old 7/11/08, 9:32 PM
gbeaumont's Avatar
I wonder how the comments would differ if you were bidding the job Marc
No Offence intended
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 7/12/08, 8:33 AM
Banned
No Offence intended
I know exactly what you mean, and you're headed down the right path. If I wanted to sell work, I'd switch gears entirely.
Old 7/12/08, 11:50 AM
" Older system with no GEC. At risk for excessive lightning damages."
Is he really saying the system is not grounded or just that there is no supplimental rod in addition to the water pipe
Old 7/12/08, 2:11 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does that mean there's a difference between "legal" and safe?
Old 7/12/08, 2:49 PM
As a home inspector I'm not concerned with "legal"...I consider the safety factor only.
While most of the described conditions are "legal" they may well be far from safe.
Old 7/12/08, 4:01 PM
Banned
Of course there's a difference. Was there ever any doubt? What was once quite legal, but no longer is legal, can now be recognized as unsafe. What is presently legal is presently also safe.
Old 7/12/08, 4:03 PM
Banned
Pot stirrer.... No GEC means that there is no grounding electrode conductor whatsoever. No need to cloud the issue with whether there's a water bond or not. "No GEC" is clear all by itelf. If there ain't one, there ain't one.
Old 7/12/08, 6:44 PM
Did he look in the meter base, or even up on the service head?
I can't imagine a PoCo installing a service without a ground electrode. That is the reason some areas around here FPL wants it to land in the meter base.
Old 7/12/08, 6:52 PM
Banned
Who said the PoCo even installed it? You're not even an electrician, have little to no field experience, you're not a home inspector either, so you're about 98% unqualified to even comment.
Old 7/12/08, 6:58 PM
Fl License BN2102, IAEI 2A,2B,2C certified SBCCI commercial and Residential inspector certified. 8 years as state electrical inspector ... I got some game.
Perhaps I mis spoke when I said the PoCo installed the "service" but they certainly suppied he drop and FPL won't do that until they look over the installation. Are you saying your PoCo will just hang the wires on the house and never look to see that there was anything there to hook it too?
BTW why the hostility?
Old 7/12/08, 7:01 PM
Banned
You betcha. Particularly considering the age of the installation. See it on a regular basis myself. Matter of fact, recently a PoCo energized a service I built, but the meter's load side cable was just hanging in mid-air inside the garage; not even a panel mounted yet. The fact that you can't imagine such a thing happening shows you're lacking in depth of experience.
