As an home inspector & not an electrician how would you report the following.
(What I mean is in the eyes of a home inspector would you report on the mentioned issues) (as an electrician I would think you would consider a sloppy install) The romex above the panel. Would you recommend securing or not report about this. The grounds being intertwined together. Should they be individualy connected to the ground bar. The bare aluminum wire has been cut to fit the lug at the top left of the panel. This is a sub panel not the main. Any other issues you would report on? |
When I (a home inspector) see "crap" like this, I defer the whole mess, rather than try to list each visible defect.
The panel and its components have been improperly and unprofessionally installed and/or modified, and should be repaired by a qualified electrician. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If this is a sub-panel what is that bare wire out the bottom for???
I expect you saw other things in the Home, plates missing, GFCIs required Covers missing ect. ..... Cookie If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
I don't think that the ground has been cut. It looks like it was previously terminated in a lug and retains the shape of the set screw. Also notice the compound around the depressed area.
The individual branch circuit ground must be terminated to the buss. Most buss bars will accept 2, of the same size, terminated in 1 hole. |
David,
Nice catch. Like Jeff P. stated....Defer the entire panel to a licensed Electrician. You've got too many issues here. It appears that the Electrician was smoking some good stuff during this installation. |
Thanks for the replies.
Since this is an educational forum would someone care to enlighten me with being specific on the violations with this panel. Are there any safety concerns or are these NEC specific violations. As Speedy mentioned why is there a ground wire at the bottom of the sub panel. Shouldnt this be attached at the main. Speaking of the main. I didnt take off this cover by the meter as it was shared with another unit. Maybe I should have. Would you? |
He didn't say but if this is a sub in a detached building it would need another ground electrode system ... or this could just be bonding pipes.
As for the combined grounds, the only real violation is they are not joined with a listed splicing method. There is nothing that says you need to take all EGCs back to the grounding bus. In fact, as long as the conductor is sized to the largest O/C device served, they can all come back on one wire. The exception to that is the swimming pool underwater light. (EGC must be insulated and unspliced) They should have secured the Romex at the top of the panel tho. |
We are just lowly HIs, and our job is to generate work for your kind Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Jeff,
I agree with Paul on that one. |
MOST DIYers think a ground rod is needed at ANY sub-panel. |
If there are breakers and a dead-front in the right side, by all means, remove the cover, but that's not how it looks from my perspective. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
| Electrician signs off 'ganged neutrals'...now what? | mgault | Electrical Inspections | 16 | 6/3/07 12:09 AM |
| Electrician or handyman repair? | srowe | Electrical Inspections | 8 | 1/4/07 10:21 AM |
| Help Wanted: Electrician (Full Time/Illinois) | ebadofsky | Miscellaneous Discussion for Inspectors | 0 | 9/12/06 8:14 PM |
| Electrician Help | bkelly2 | Plumbing Inspections | 1 | 4/27/06 7:56 PM |
