Old 12/14/13, 9:34 AM
John W. Shelton John W. Shelton is offline
Default what is insulated cloth wiring
What is the difference between cloth wiring and insulated cloth wiring? And do you have a picture? Is the attached picture insulated cloth wiring or cloth wiring? Citizens will allow insulated cloth wiring but not plain cloth wiring.
John Shelton
Aim Higher Home Inspections
http://www.aimhighinspections.com
http://www.aimhighinspections.net
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/14/13, 9:37 AM
Roy D. Cooke, Sr's Avatar
Default Re: what is insulated cloth wiring
Rubber insulation under the cloth .
They stopped making it in Canada about 1950~.
If you do not search for more ,
......You will never find it.
............. Roycooke@hotmail.com
...................705-999-1030
Old 12/14/13, 9:54 AM
Robert Meier's Avatar
Robert Meier Robert Meier is offline
Typically these are type RH conductors which are tin coated copper with a rubber insulation and a "cloth" covering. The tin keeps the copper from reacting with the rubber.
Old 12/14/13, 10:02 AM
so what is my picture? Plain cloth wiring? I have been asked to specify on my 4-point, if it is insulated or not... If it is two wires wrapped in cloth which enters the sub panel, is it just cloth wiring?
John Shelton
Old 12/14/13, 10:04 AM
It's insulated. Where are you getting this information of a the definitions/difference between cloth wiring and insulated cloth wiring?
Old 12/14/13, 10:15 AM
Interesting never heard that before .
I was taught the wire was tinned to make it easier to solder as that was how all joints where made back then ,
Old 12/14/13, 10:39 AM
Jeffrey R. Pope, CMI's Avatar
Jeffrey R. Pope, CMI Jeffrey R. Pope, CMI is offline
Directly from the uninformed insurance company...
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE «
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/14/13, 10:43 AM
love it never heard of that insulation before .
Old 12/14/13, 2:20 PM
Erik Schmidt Erik Schmidt is offline
I would call it insulated wiring, which it definitely is. Cloth wiring would not work very well, as cloth is a poor conductor of electricity, which is why they make wires out of copper, gold, aluminum, etc. Probably best to leave that last bit out of your report lest insuranceco might mistake you for a smartypants.
Erik Schmidt
East Side Home Inspection
Edmonton Alberta
780 477 2666
Old 12/14/13, 6:26 PM
Joseph M. Whitt Joseph M. Whitt is offline
It was tinned because the rubber has sulfur in it that reacts with copper.
Mike Whitt
Contractor/Instructor
Old 12/14/13, 6:41 PM
Sean Fogarty's Avatar
All aged wiring had some type of rubberized or encased coating. Even knob and tube had some type of material which seperated the wire from the cloth sheathing. I can't tell anymore becuase its so old its brittle and crubles when messsed with.
They could be specifing the strand itself. Older wires were cloth wrapped like Roys picture.
Later wiring used in the late 50's and 60's was actually a rubber coated strand. The outer casing was still cloth wrapped but the hot and neutral strands were simmilar to modern wiring.
The larger wiring in your picture would be cloth covered, but I would want to know if it specified single or multi strand. Even with newer single strand wiring used up through the 70's, some of the larger wiring was still cloth covered.
Fogarty Inspection Services Group of Palm Bay FL
Florida Licensed Home Inspector #8351
Certified Master Inspector
Home inspections, Commercial Inspections, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
fogartyinspectionservices@gmail.com
www.homeinspectorpalmbay.com
Old 12/14/13, 7:04 PM
The stuff in the first photo appears to be stranded. Why would stranded vs. solid matter?
Old 12/14/13, 8:44 PM
I personally don't know why, I was just using the reference from past observation. My only thought on that was it seemed to still be used after single strand started to transition over to newer materials. At least thats what I have commonly seen.
I would think it wouldn't matter, but only the insurance company could answer that one.
321-506-5125
Old 12/15/13, 10:05 AM
Charley L. Bottger's Avatar
I think its about age and what was used and or available for residential during such and such time frame. We all have seen the transition from K&T basically starting pre 1920's thru present day we can pretty well date a lot of homes by the type of electrical wire used
http://www.oklahomathermalinfraredimaging.com/
http://www.freedomexpressinspections.com/
Master HVAC Mechanic Retired
Level III Thermographer # 8486 Infraspection Institute
CMI Certified Master Inspector
Residential/Commercial Inspections
Moisture Intrusion Expert Witness
580-268-3340
Old 12/15/13, 10:10 AM
Background of question. I did a 4-point on a sale. The lady was able to get insurance based on my 4-point. 6 weeks after closing she received her cancellation notice as I checked the box knob and tub/cloth wiring. I was asked to review as she fixed the plumbing and wanted a second look at the electrical. I redid the 4-point and received the e-mail below from the insurance lady…
On a side note, why did they close on my first 4-point and then cancel her 6 months after closing? If this is the standard I need to be educated so I can warn the buyer…
Hi John,
Lucy has not yet called me back. Are you able to send me a copy of the inspection?
Also, Citizen's will accept insulated cloth wiring, but they will not accept cloth wiring if its not insulated...could you make sure the inspection specificies if it is insulated or not?
John Shelton
Evaluating your home's wiring system mcyr Electrical Inspections 2 8/13/13 9:00 PM
Cloth wiring vs. cloth braided wiring hlobdell Miscellaneous Discussion for Inspectors 2 6/3/13 7:36 PM
Knob and Tube & Cloth Wiring rmurphy1 Florida Inspectors 2 8/11/12 11:37 PM
