Old 11/17/08, 1:10 AM
pabrioux pabrioux is offline
Default Insulating Gloves
I've found a few old threads on this topic, but none that answered my question, so hopefully someone can offer some advice.
It seems some inspectors wear them, some don't. Anyhow, if one was to wear them, what class of these insulating gloves should we buy/would be adequate?
Class 00 for up to 500 volts AC
Class 0 for up to 1000 volts AC
Class 1 for up to 7,500 volts AC
And the list goes on.
I guess, what kind of voltage could be present at a main service panel?
Thanks a lot! Any info is appreciated!
Paul-Marc
Old 11/17/08, 4:33 AM
canderson canderson is offline
Exclamation Re: Insulating Gloves
Paul-Marc
Paul-Marc,
I worked for a major utility for 15 years. I agree with you that you should select the rating that would meet/exceed the known voltage for which you may come in contact with.
Also, it is just as important to check the manufacturer's application guide to be sure they are rated and certified for your intended use. A good glove has different colored layers which makes daily maintenace inspection for any defects or damage much easier to spot. Never use a damaged/defective glove. A good safety practice is to destroy any damaged glove by cutting it in half and preventing inadvertant use.
Carl
Old 11/17/08, 8:57 AM
Default Re: Insulating Gloves
Ok, my brain was tired...or something! After a little thought, I guess utility companies are required to supply a split-phase 240 volt feed to the house. Therefore, class 00 gloves should be adequate.
With a standard two hot and one neutral coming in as service entrance wires, could voltage exceed 240 somehow?
Thanks for the reply Carl!
Paul-Marc
Old 11/17/08, 9:14 AM
Michael Larson's Avatar
Yes absolutely.
Peak to peak voltage is not 240.
It is 340 V L1 to L2.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 11/17/08, 9:40 AM
Paul,
Do yourself a favor and go purchase NFPA 70E. It will answer your questions.
http://www.nfpa.org/catalog/product....order_src=A291
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 11/17/08, 12:11 PM
Ok, Michael and Kevin, thanks for the input and for the link. I guess it's 240 volts X 1.414 to get the peak to peak voltage of 340? I'm reading about it now. Thanks for helping me out.
By the way, do either of you wear these gloves?
Paul-Marc
Old 11/17/08, 12:25 PM
jkogel jkogel is offline
http://www.nachi.org/forum/f63/episo...west-post.html
Check out what this electrician wears.
BTW, there is no need for an inspector to ever touch any wiring in the course of an inspection. I personally do not rely on gloves.
John Kogel
www.allsafehome.ca
Old 11/17/08, 12:34 PM
I don not use these but have considered starting to because they give a better grip on the panel cover.
But there really is no reason to come in contact with any of the wire in a panel.
We are doing a visual inspection.
Michael Larson
Hudson, WI
InspectraPro
and
Old 11/17/08, 12:39 PM
Banned
I have been told of cases where the panel case metal is energized. It only takes a few milliamps in the wrong situation to cause a problem.
Old 11/17/08, 12:48 PM
Which is why I check it first with a non contact voltage tester.
Do you?
Michael Larson
Hudson, WI
InspectraPro
and
Old 11/17/08, 5:50 PM
klott's Avatar
klott klott is offline
It is the low voltage that stops your heart.
"It's not what you believe that matters...it matters what you believe!"
Old 11/17/08, 10:17 PM
My non-contact tester starts beeping when I get within 6 inches of any live wires. I thought it was a fairly good one when I bought it. But anyways, the tester starts beeping anywhere near the service panel, so it doesn't tell me if the panel cover is energized or not. It seems too sensitive, but non-adjustable.
Old 11/21/08, 12:15 AM
Jason Kaylor Jason Kaylor is offline
Please Note: Jason Kaylor is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you decide to get high voltage gloves, you might want to check out Salisbury. Not sure of their site, or where to get them, but I have heard nothing but good reviews on them.
JJ
Old 11/22/08, 1:50 AM
Thanks Jason, yep, those are the ones I had seen actually at a website I found while searching online: http://www.corvib-int.com/
I know it's just a visual inspection and I shouldn't be touching anything but I might get some just for taking the panel covers off anyways.
Paul-Marc
Old 11/27/08, 10:11 PM
Ted Allen Ted Allen is offline
I went over this so many times a year or so back...
If you are going to open dead fronts you need to wear some safety glasses and at the VERY least some NEW DRY leather gloves. I prefer to use 00 rated rubbers under my gloves , but that's just me.
The biggest threat you face is the possible ARC FLASH if you have some loose crap inside the panel you are opening.
Be safe.....
insulating a slab with radiant heat jcampbell Inspecting HVAC Systems 3 3/26/08 11:15 PM
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 72 3/12/08 12:19 AM
cold climates: insulating floors w/plumbing above cold crawlspaces kshepard Plumbing Inspections 6 9/26/06 12:09 AM
Linemans gloves gporter Electrical Inspections 24 4/8/06 12:17 AM
