Looking for a narrative explaining why the insulation on the main service conductors shouldn't be stripped back too far.
George Russell George Russell Professional Inspections Austin,Texas TREC # 10215 512-296-9538 http://georgerussellprofessionalinspections.com/ http://www.facebook.com/austinhomeinspections |
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Please explain the hazard you see.
Although it may be sloppy IMO there really is no hazard or violation worth mentioning.
I agree - no big deal here. The only real issue you have is with the grounding conductors that are attached to the neutral terminal on a remote (sub) panel.
Are you sure it's a sub panel? Since it's on the outside of the building I would guess that the conduit on the right side comes from the meter enclosure.
No, not completely sure. I can see the bonding strap now that you've enlarged the picture, so it's possible this is service equipment. Although I wouldn't expect to see both a neutral and EGC coming from the meter enclosure.
George, first off let me say that I do not think the wires in your photo are excessively stripped. If I did, I might use something like:
It's the main. The sub is in the garage. Thanks All!!
What are the other breakers for?
I see a couple of grounded conductors and all are 240 circuits. Dryer and kitchen stove? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
It could use one of these
BestInspectors.Net
& Real Estate Training Academy Inspection Report Software for Windows - iOS - Mac - Android Continuing Education Home and Commercial Building Inspection - Skilled Trades – Real Estate – Appraisal – NFPA 921 http://www.bestinspectors.net est. 1992 |
I guess you're right. The stranded AL comes from the other side...
These wires are stripped too far:
![]() My comment on the report: "It appears that the insulation has been stripped excessively on the right side of the panel at the breakers. Recommend having a licensed electrician repair as needed." David Hays All Points Home Inspections LLC Denver, CO 720-670-0366 allpointshomeinspect@yahoo.com www.allpointshomeinspections.org Last edited by dhays; 7/11/11 at 7:20 PM.. |
Most breakers have wire strip lengths/gauges marked on them. I would expect that main panel lugs would have something similar in the instructions or listing. And the reasons for that would be similar.
That does appear to be more wire stripped off the feeders than I would expect to see. Might be a concern related to incidential contact with a bare feeder wire for someone working inside that panel. It's also possible that an appropriate amount of the insulation was stripped off, but the wire was not fully inserted into the lug. I would have made a note of it, but not as a significant issue if there appeared to be a solid connection. Maybe something along the lines of ... Quote:
JMO & 2-Nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 7/12/11 at 3:26 PM.. |
| History of Insulation with Masonry | mcyr | General Inspection Discussion | 7 | 2/27/08 7:53 PM |
| Insulation blankets | rray | Plumbing Inspections | 35 | 12/9/06 9:38 AM |
| Wood fiber insulation? | bwooddell | Interior Inspections | 3 | 3/22/06 9:58 PM |
